**Today Only 13/03/2012** Corsair Flash Survivor® 32GB USB 3.0 & Corsair Vengeance 8GB 1600MHz Singl
22 Aug 2010
Today Only,
we have the ultra durable, fast and reliable Corsair Survivor USB 3.0 pen which is encased in aircraft-grade aluminum housing and is waterproof to 200 metres. A pretty awesome USB pen if you ask me!
We also have Corsair Vengeance 8GB 1600MHz Single Channel Module memory. Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget
Corsair Flash Survivor® 32GB USB3.0 Flash Drive (CMFSV3-32GB) @ £31.99 inc VAT
Your files are important — that's why you're taking them with you. Flash Survivor USB 3.0 helps keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
- Capacity: 32GB
- Read: 80MB/s
- Write: 40MB/s
- Interface: USB3.0
- Warranty: 5 Years
Only £31.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (1x8GB) DDR3 PC3-12800C10 1600MHz Single Channel Module (CMZ8GX3M1A1600C10) @ £41.99 inc VAT
The new 8GB Vengeance DDR3 memory operates at 1.5V for compatibility with the new 2nd generation Intel® Core™ processor family and is guaranteed to operate at 1600MHz. Providing 8GB of rigorously-screened DRAM on a single module allows gamers and performance enthusiasts to build systems with 32GB of high-performance memory.
"Vengeance DDR3 memory is the premier choice for reliable, overclockable DRAM for system builders on a budget," said Giovanni Sena, Director of Memory Products at Corsair. "Our kits based on 8GB modules give builders, system integrators, and gaming enthusiasts the power to break the 16GB barrier."
Features
- 8GB Module
- Each module is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested at 1600MHz, Vdimm = 1.50V, at latency settings of 10-10-10-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 10-10-10-27 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £41.99 inc VAT.
ORDER NOW
