**TODAY ONLY! 13/05/2014** Dell UltraSharp 27" Monitor & Samsung 22" Monitor
OcUK Staff
4 Feb 2013
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey @ £399.95 inc VAT
Cinema-like clarity shines on the expansive 27" DellTM UltraSharp U2713HM monitor. Comfort settings and connectivity options help keep you productive. WQHD resolution and accurate colors out of the box: Superb clarity with 2560 x 1440 resolution and over 3.6 million pixels. Features a color gamut of more than 99-percent sRGB.
Excellent comfort and usability: Full adjustability including swivel, tilt, height adjustability and pivot which lets you easily switch to portrait mode. Eco-friendly design: Compliant with the latest environmental standards and made using environmentally conscious materials
2560x1440 WQHD resolution: Over 3.6 million pixels provide amazing clarity on a spacious 27" LED-backlit display. Easily adjust screen brightness to suit your environment. Accurate color right out of the box: Carefully color calibrated at the factory, the U2713HM monitor features more than 99-percent sRGB color space for impressive color from the moment you set it up. Wide-angle viewing: Uncompromised color consistency across an ultra-wide viewing angle of 178°/178° gives you broad viewing flexibility and lets you collaborate easily.
Full adjustability: Work comfortably and view images from a variety of positions with swivel and tilt. Easily switch to portrait mode with pivot. Set your U2713HM to the optimum height with a height-adjustability range of 115mm. Latest connectivity options: Seamlessly connect your monitor to your desktop, laptop and peripherals such as digital cameras and Blu-ray or DVD players. Digital and analog connections include four USB 3.0 ports, DisplayPort 1.2, DVI (HDCP) and HDMI. Stay productive with Dell Display Manager: This one-stop software tool lets you quickly access applications such as Auto Mode, Easy Arrange and PowerNap. Use Auto Mode to adjust or auto-assign preset modes to specific applications. Use Easy Arrange to neatly tile your applications, arranging them in your preferred layout
Meets latest environmental standards: The U2713HM monitor meets EPEAT® Gold and TCO Certified Displays standards, is ENERGY STAR® qualified and CECP compliant. Made with responsible materials: This monitor is made with arsenic-free glass, a mercury-free panel, uses 25-percent post-consumer recycled plastics in its chassis and BFR/PVC-free laminates in its circuit boards. The U2713HM also ships with environmentally responsible packaging. Helps save resources: Enable PowerNap mode to reduce power consumption by dimming the monitor to minimum brightness or by putting it into sleep mode.
Features:-
- LED Backlit
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 2,000,000:1
- Brightness: 350cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI, 1x DisplayPort,
- 5-Port USB3.0 Hub
- VESA Compliant
- Dimensions: 639.3mm (25.17'') x 200.3mm (7.89'') x 424.3mm ~ 538.9mm (21.22'' ~ 16.70'')
- Weight: 10.20kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Only £399.95 inc VAT.
ORDER NOW
_____
Samsung LS22C570HS 22" Widescreen LED Monitor - Glossy Black @ £99.95 inc VAT
Part of Samsung’s LED Monitor Series 5 range, the LS22C570HS is a slim 21.5” monitor with a modern, inspiring style. It has been packed full of technology to provide enhance functionality, giving you improved picture quality and a wide viewing angle.
Series 5 monitors feature Mega Dynamic Contrast Ratio, which delivers vast levels of colours to improve moving image quality, displaying blacks at their darkest and other colours at their brightest. This not only improves picture quality and increases vibrancy, but also helps to deliverer clearer picture clarity. A static contrast ratio of 1000:1 of ensures high quality still images and text.
A wide viewing angle of 178° horizontally and vertically gives you more options of where you can see the screen from without losing image definition. This ensures crisp, clear and perfect colours from almost any angle.
Resolution up to Full HD 1920x1080, ensures that high definition images and video will display in HD, while text looks sharp and well defined. A rapid response time of 5 milliseconds means this monitor can keep up with fast moving action, while the LS22C570HS can show up to 16.7 million colours, to give you the variety that you see in real life.
Samsung’s Magic Upscale technology improves image quality to give you enhanced picture quality, no matter what the resolution of the original image. It prevents image degradation when scaling up and presents brilliant, clean colours and sharp images.
Eco Saving mode will assist you in saving power and money. You can choose from three options (50%, 25% and Power Saving off) to help make power saving easy and tailor your monitor use to suit your needs.
HDMI and VGA inputs give you the ability to connect this monitor to a wide variety of devices, from desktop PCs and laptops to Blu-ray players and games consoles.
Specification:-
- Screen size: 21.5"
- Screen Type: VA Panel
- Resolution: 1920x1080
- Response time: 5ms
- Contrast ratio: Mega DCR (static 1000:1)
- Brightness 250cd/m²
- Viewing Angles: 178/178
- Connectivity: 1x HDMI, 1x VGA, Audio Out
- Speakers: NO
- Colours supported: 16.7 million
- Dimensions (monitor only): H311.91 x W507.4 x D99.82 mm
- Dimensions (monitor with stand): H407.6 x W507.4 x D189.9 mm
- Warranty: 2yr
Only £99.95 inc VAT.
ORDER NOW
