Bitfenix Aegis Core Micro-ATX Chassis - Black @ £49.99 inc VAT
AEGIS Core features a beautiful rounded shield-inspired front and a sporty fresh design all around. It comes in black, white and 3 vibrant colors (red, blue, yellow) and supports an impressive amount of fans and radiators: up to 8 120mm fans or 5 140mm fans, dual 280 radiators or a 360 and 240 combo.
The 3 tool free storage cages are modular and can be moved around or taken out all together, in which case there is still a hidden 2.5" slot behind the PSU and a "show off" 2.5" slot next to the mainboard tray. Besides some nice dust filters on the top, front and bottom, it comes with a built in fan controller, a stylish PSU cover, a rubber padded pump bracket and last but not least a neat reservoir bracket, that let users attach a reservoir or pump/res combo to a 240 or 360 radiator.
Features
- Bold yet Timeless design - Beautiful smooth lines
- Large top panel to channel airflow and block noise
- Closed front panel with large side vents to block noise
- Available in black, white and 3 vibrant colours
- Mixed colour internals, not just plain black or white
- Huge Sidepanel Window
- Removable PSU Shroud Cover
- Massive Backplate Access for High-End CPU coolers
- Supports 380mm GPU's
- 5 PCI slots for optimum Dual GPU support
- Removable Toolless 2.5"/3.5" bays
- Up to 220mm PSU support
- Up to 8 fans support
- Integrated Fan Controller
- Magnetic Dust Filters
- Supports up to 360mm radiators
- Comes with bundled reservoir and pump brackets
Specification
- Materials: Steel Alloy, Polymer, Acrylic (window)
- Colours: Black/Black
- Case Dimensions (mm/in): 205 x 470 x 480 (WxHxD) - 7.95 x 18.15 x 18.38 (WxHxD)
- Box Dimensions (mm/in): 255 x 530 x 505 (WxHxD) - 10.03 x 20.86 x 19.88 (WxHxD)
- Box Volume: 2.4 ft³/cuft - 68.25L - 0.068m³
- Case Weight (kg/lbs): 6.7 / 14.8
- Box Weight (kg/lbs): 7.8 / 17.2
- Max Heatsink height (mm/in): 170mm / 6.7
- Max AIO support (push/push pull): 360 / 360
- Max radiator support (push/push pull): 360 (85mm) + 240 (60mm) / 360 (60mm) + 240 (60mm)
- Max VGA length (mm/in): 380mm / 14.9 with HDD cage installed (depends on front radiator configuration)
- Motherboard Micro ATX, Mini-ITX
- 3.5” Drive slots: 4 (two removable cages with 2 tool less slots each)
- 2.5” Drive slots: 4 (one removable cage with 2 tool less slots each, one slot next to the Mainboard, one slot behind the PSU)
- Max HDD capacity: 40TB (4x 8TB 3.5” + 4x 2TB 2.5”)
- Max SSD capacity: 16TB (8x 2TB 2.5”)
- Fan Controller: 4 fan headers, 3 speeds (12v, 7v, 5v) with 3 indicator LEDs (white)
- Cooling Top: 3x 120mm or 2x140mm – click on dust filter
- Cooling Front: 3x 120mm or 2x140mm – magnetic dust filter
- Cooling Bottom: 1x 120mm – magnetic dust filter
- Cooling Bottom: 1x 120mm (included)
- PCI Slots: 5
- I/O: USB 3.0 x 2, Audio, Mic, Power, Reset, Power LED (white), HDD LED (white)
- PSU: PS2 ATX, up to 220mm in length, intake from case interior or case bottom
- Special Features: Aluminium Bitfenix Logo sticker, Fan Controller, PSU cover, Magnetic Dust Filters, Pump bracket, Reservoir Bracket, 2 Removable HDD Cages, 1 removable SSD cage, Tool less HDD and SSD system, Hidden 2.5” slot, 2.5” Show Off slot, Window Sidepanel, Rubber Grommets.
Only £49.99 inc VAT.
ORDER NOW
________
Saitek Pro Flight X55 Rhino H.O.T.A.S. System @ £129.95 inc VAT
Military-grade Flight Sim Precision
Inspired by controls found within actual fighter planes, the next-gen X-55 Rhino H.O.T.A.S. System for PC provides utmost control over simulated aircraft. Built to the same exacting standards of Saitek's award-winning Pro Flight accessories range, the X-55 Rhino delivers a multitude of customizable options never before seen in an H.O.T.A.S. System. Whether flying a modern fighter, single- or multi-engine aircraft, or even a retro single-seat plane, the X-55 Rhino supplies all the control surface options required to achieve the exact level of aerial performance aspiring pilots demand.
Enhanced Stick Accuracy
During virtual flight – just like true flight – the accuracy of an aircraft's control surfaces is of paramount importance. The X-55 Rhino's control surfaces are incredibly accurate, courtesy of an all-new 16-bit aileron and a 16-bit elevator axis, each employing hall-effect sensors. Developed from the ground up, Saitek's 16-bit axis solution enables extremely precise flight.
Adjustable Stick Force via Advanced 4-Spring System
A ground-breaking, adjustable stick spring system allows pilots to alter the force required to move the stick. Four springs of varying resistance are included to provide a total of five different options. Choose the spring – or no spring at all – which best accommodates your style of flying.
Twin Throttles with Friction Adjuster and Throttle Lock
Using a twin-engine throttle controller is the only suitable method for manipulating a virtual twin-engine aircraft. The X-55 Rhino boasts twin throttles – ideal for situations in which your primary engine is disabled and you're down to one – and also provides the option to adjust the friction required to move them. And if your aircraft of choice is single-engine, a handy throttle lock effectively converts the twin throttles into a single unit.
Bonus Toggles and Rotaries on Backlit Throttle Base
Flight sim accessories used by today's virtual pilots require the highest level of control and customization. The X-55 Rhino showcases additional toggles and rotaries, not based on any particular aircraft, around the throttle base. Seven extra three-way toggle switches and two rotaries allow you to customize this H.O.T.A.S. System to your own specifications.
Individual USB Connectors
The X-55 Rhino's stick and throttle units each utilize their own separate USB connection, offering greater flexibility during customization. You're free to situate the controls exactly where you want them, without the need to keep them tethered to each other.
H.O.T.A.S. Configuration Software Enables Programmable Controls
Saitek's new software provides the ability to completely customize all of the X-55 Rhino's axes and buttons. On the axis side, you can adjust deadbands and response curves to fine-tune axes to respond just like an aircraft's real-life counterparts. On the buttons and toggle side, you can assign any number of in-sim directives, such as speed brake, flares, target lock and pickle weapon. The software also allows programmability for an array of mouse and keyboard commands – from basic single-key inputs to very advanced, timed, and macro commands.
Build the Ultimate Virtual Cockpit
Transform even a modest PC into a virtual cockpit and experience the staggering realism of different flight and emergency situations – complete with realistic weather and flight conditions. Using the X-55 Rhino as a foundation for Saitek's modular accessories, easily add Combat Rudder Pedals and a multitude of Switch, Navigation, and Instrument Panels to fully customize your flight simulator. Commercial or private, seasoned or novice, you have the ability to equip your flight simulation setup with all the essentials needed to vastly improve your skill set and muscle memory.
Product Includes:
- X-55 Rhino Stick Unit with USB Connector Cable
- X-55 Rhino Throttle Unit with USB Connector Cable and Green Backlighting
- Spring System with 4 Springs of Varied Resistance
Compatible with ALL Major Flying Games with the Saitek X-55 H.O.T.A.S. Configuration Software,
Only £129.95 inc VAT.
ORDER NOW
Features
Specification
- PCI Slots: 5
ORDER NOW
________
Product Includes:
ORDER NOW
