**Today Only 13/06/2012** Sandisk Ultra SSD 120GB 2.5" SSD & Creative Sound Blaster X-Fi Titanium HD
22 Aug 2010
Today Only deals!!!
Sandisk Ultra SSD 120GB 2.5" SATA II Solid State Hard Drive - (SDSSDH-120G-G25) @ £59.99 inc VAT
Upgrade your laptop to high-performance and extend its battery life with the reliable SanDisk Ultra® SSD. You’ll enjoy faster boot-ups and shutdown in up to half the time compared to a 7200 RPM hard drive§. The SanDisk Ultra SSD is backed by rigorous shock and vibration testing and a 3-year limited warranty†. The SanDisk SSD features no moving parts, quiet operation, and low power consumption as compared to a 7200 RPM hard drive.
- SandForce SF-1222 Controller
- Upto 280MB/sec Read performance
- Upto 270MB/sec Write performance
- SATA-II (3Gb/s) (Compatible with all SATA versions)
- Operating temperature: 0c to 60c
- Power Active: 0.43W
- Shock Resistant: 1500G @ 0.5 msec
- Vibration: 2.17gRMS, 5-700Hz
- Delivers reliability, durability, and performance for your laptop or desktop
- Faster system boot up and shutdown .the rugged SanDisk Ultra SSD can boot up or shut down your system up to twice as fast as compared to a 7200 RPM HDD˜
- Speedy read and write performance.up to 280 MB/secö read and up to 270 MB/secö write performance Designed for high durability.engineered to withstand shocks and vibration
- Long-term endurance - the 60 GB SanDisk Ultra SSD can withstand at least 40 terabytes* of data written to it over lifetimeĢ, while the 120 GB and 240 GB drives can withstand at least 80 terabytes and 120 terabytes of data written, respectively
- Lower power consumption - as compared to a standard 7200 RPM Hard Disk Drive
- Noise reduction - the SanDisk Ultra SSD provides quiet drive operation
- 3y Warranty
Only £59.99 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium HD Sound Card (70SB127000001) @ £119.99 inc VAT
The Sound Blaster X-Fi Titanium HD provides the highest quality audio playback of any sound card Creative has ever introduced and includes THX TruStudio PC audio technology, bringing together two of the most respected names in sound quality to provide an unparalleled audio experience on the PC. The Sound Blaster X-Fi Titanium HD features audiophile-grade components for high-quality playback of music, games and movies, including 122db SNR Digital-to-Analog Converters (DACs), the highest signal-to-noise ratio ever produced by a Creative sound card. Replaceable OP-amp provides the flexibility to further customize the audio experience through different sound coloration. If you are serious about your PC sound, this is the ultimate Sound Blaster experience.
- High-Fidelity audio performance D/A, A/D converter with SN ratio of 122dB with 0.001% (THD) distortion
- High quality audiophile grade performance components designed to eliminate noise, while dramatically improve sound field dynamics in high and mid tones
- Headphone out with 115dB, 24bit/96kHz support High-Definition (HD) quality sound for original playback
- Personalize sound field experiences with swappable OP-amp sockets
- THX TruStudio PC effects transforms your experience into a true High-Definition (HD) multimedia emotional journey
- Hardware-powered 3D positional audio and EAX 5.0 effects provide stunning audio realism over headphones and speakers
- ASIO recording support with latency as low as one millisecond with minimal CPU load. Dolby Digital and DTS encoding enables one-step single-cable connection to home entertainment systems, with included optical cables
Only £119.99 inc VAT.
ORDER NOW
Can you keep one of those sound cards on hold for me? I have a meeting in a short while and will order one around 11:00.
edit -nvm ordered
dammit I clicked to goto shop then realised its only the ultras :(
Thought OcUK were doina crazy deal ont he extremes there lol.
Must remember to wake up before shopping xD
EDIT: and also before typing :p
Would it be worth waiting and getting an Extreme series SSD for my system? Or should I just jump on this Ultra? What would the performance difference feel like on my system between the two bearing in mind my mobo is SATA 2?
Ta
Ta
If the extreme series is faster then you won't benefit much from the extra performance. SATA2 maxes out at 280MB/s.
I bought my SSD at such a bad time a few months ago, how annoying. The thought of a 120gb ssd in my laptop is tempting though.
How do you go about doing that though? I have a 1TB hard drive in my laptop so I don't really want to replace that, would I have to take the dvd drive out?
It depends on your laptop, I'm very tempted to pick up a 256gb SSD for my laptop and stick the current hard drive in a portable enclosure.
That's SSD is good deal for laptop as many laptop don't use Sata III only Sata II. So, these SSD will be good on laptop. But 120GB might not be enough after installed Windows 7 Ultimate 64 bit and all drivers & online updated approx use of closer 28GB and leave you around 82GB for applications and storages (after formatted SSD will reduce to 111GB from 120GB)
samdisk ultra is a fine choice for sata 3gps connection ie older board but not if you have sata 6gbps connections available.
see storagereview for a review of the ultra drive @3gbps and some other drives specced at 6 but tested at 3 and 6gbps. Getting a 6gbps drive 9extreme) and putting it on a 3gbps mobo would be a waste.
PS I find 120 gb is fine for win 7 and applications (office) etc few steam games, bung media fiels on a decent hdd
