**Today Only 13/06/2013** HIS HD 7770 iCooler 1024MB & EVGA GeForce GTX 770 Superclock ACX 2GB
22 Aug 2010
Today Only Deals! Be quick and you might be able to scoop some of the lowest prices in the UK!
HIS HD 7770 iCooler 1024MB GDDR5 PCI-Express Graphics Card @ £79.99 inc VAT
The card is equipped with the widely acclaimed HIS iCooler – certified by HIS that generates less than 28 dB in 2D mode. HIS iCooler provides an outstanding cooling performance and quiet environment. With HIS iCooler, the life span of the card is maximized while the noise level is minimized!
HIS iCooler excels in noise management. It's extremely quiet and noise level is less than 28dB in 2D mode - much lower than the original cooler on reference design. You feel the quietness when viewing photos, browsing webs and checking your email.
Features:-
- Core Clock: 1000MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4500MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 640
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Only £79.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 770 Superclock ACX 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2774) @ £349.99 inc VAT
Fast just got faster with the next-generation EVGA GeForce GTX 770, a high-performance graphics card designed from the ground up to deliver high-speed, super-smooth gaming.
EVGA is also introducing a brand new cooling design; the EVGA ACX cooler. This revolutionary double ball bearing fans with an average lifespan of 12 years. This is 4x longer lifespan vs competitors sleeve bearing fans! Not to mention this fan is silent, in factr it is 15% quieter on average!
The EVGA GeForce GTX 770 is stacked with unique gaming technologies like NVIDIA GPU Boost 2.0 that make it fast. Really fast. So nothing will hold you back from taking on - and dominating - your most challenging games.
Specification:-
- Core Clock: 1111MHz (GK104)
- Core Boost Clock: 1163MHz
- Memory: 2048MB GDDR5
- Memory Clock: 7010MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2220MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £349.99 inc VAT.
ORDER NOW
don't know if its me but i can't see what the price was before the deal on any of these daily deal threads. would love to know what the saving is :)
was £94.99
Now £79.99 inc VAT
Saving £15.00
was £371.99
Now £349.99 inc VAT
Saving £22.00
they are always on the home page ;)
