**Today Only 13/09/2012** MSI HD 7970 OC 3072MB FREE SLEEPING DOGS & Antec Soundscience Halo 6 LED K
22 Aug 2010
Today Only deals, limited deal stock available!
MSI HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card with FREE Sleeping Dogs PC Game @ £299.99 inc VAT
As AMD is going to launch its latest HD 7000 series GPU on Jan. 9th, 2012, MSI also will release R7970-2PMD3GD5 graphics card at the same time. MSI R7970-2PMD3GD5 has exclusive GPU Overvoltage support through MSI's Afterburner utility allowing amazing overclocked performance from the get-go. Equipped with 3GB GDDR5 memory allows for the unprecedented memory bandwidth levels needed to run today visually hottest DirectX 11 titles at extreme resolutions across multiple displays. Stability is guaranteed through the use of All Solid Capacitors making sure the R7970-2PMD3GD5 and R7950-2PMD3GD5 have an ultra-long lifespan even under the stress of continuous gaming. DisplayPort 1.2 and HDMI 1.4a connectors allows all new audio and video formats like Blu-ray 3D Stereo, "Deep Color" (for true natural color representation) and 7.1 High Bitrate audio to be presented on up-to six displays through AMD's Eyefinity Technology.
MSI's R7900 series graphics cards are the first graphics cards in the world to support the new PCI Express Gen 3 format. With a processor and mainboard that has PCI Express Gen 3 capability, users will be able to enjoy maximized gaming performance via the ultra-high 32GB/S bandwidth. The R7900 series graphics cards have also adopted the brand new AMD 28nm graphics chip to provide higher performance computing compared to previous generation 40nm products.
MSI's R7970-2PMD3GD5 graphics cards are equipped with the popular Afterburner tuning software, allowing users to adjust the core voltage and improve overclocking potential. In addition, Afterburner also features bundled Predator in-game video capture, remote monitoring capabilities via mobile phone, as well as Kombustor GPU stress testing and other amazing features at no extra charge, providing an exceptional software suite for users of the HD 7000 series graphics cards.
MSI's R7900 series graphics cards support AMD's exclusive Eyefinity multi-monitor display technology. The expanded field of view is perfect for professionals and hardcore gamers. The new MSI R7900 series cards support next-generation Display Port 1.2 and HDMI 1.4a interfaces with stereoscopic 3D capability, as well as 7.1 channel lossless high quality TrueHD and DTS-HD audio formats, providing users with the best audio and visual experience possible.
MSI's R7970-2PMD3GD5 has adopted all solid capacitors. The aluminum core is capable of maintaining a high degree of stability even when working under full loads over extended periods of time. With a 10-year lifespan, MSI rids users of concerns over potential crashes or delays that are caused by system hardware overheating, further providing users with the best computing experience possible.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1010MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5500MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
- All Orders placed on the 30th August 2012 and after shall recieve a FREE copy of Sleeping Dogs PC Game worth £29.99 completely FREE (Subject to availability) - You will recieve your gamecode from 7th September onwards in the email address you provided when placing your order!
Only £299.99 inc VAT.
ORDER NOW
Antec Soundscience Halo 6 LED Bias Lighting Kit - White @ £7.98 inc VAT
The soundscience halo 6 LED bias lighting kit™ makes it easy to outfit your monitor with professional backlighting. Bias lighting is an illumination technique for reducing eye fatigue and increasing perceived image clarity during long gaming sessions and extended periods of computer use. The halo 6 LED bias lighting kit™ adds a subtle white backlight to your monitor, reducing the eyestrain caused by differences in picture brightness from scene changes in movies, TV shows and video games. The color and brightness of the LEDs are carefully calibrated to achieve the optimal viewing experience. Bias lighting also increases your monitor’s perceived contrast ratio – making blacks blacker and colors more vibrant. Installation is easy – simply attach the LED strip to the back of your monitor and insert the USB plug into an open USB port on your computer or powered USB hub. The soundscience halo 6 LED bias lighting kit™ complements any monitor up to 24” in size.
- Requirements: LCD monitor up to 24” in size placed against light colored wall; available USB port or powered USB hub
- Certifications/Safety: CE, RoHS
- Unit Dimensions: Cable: 1300 mm / Light Strip: 370 mm
- Net Weight: 1.0 oz / 28.3 g
- Product Warranty: 2 year
Only £7.98 inc VAT.
ORDER NOW
