**TODAY ONLY! 13/11/2013** Double HIS graphic card goodies!
OcUK Staff
4 Feb 2013
his hd 7950 iceq boost 3072mb gddr5 pci-express graphics card (h795qc3g2m) **free shipping** @ £199.99 inc vat
the world's first 28nm gpu. the revolutionary new gcn architecture. ready for directx 11.1. pci express 3.0. the amd radeon™ hd 7950 is your personal checklist for ground-breaking technology. the next generation of amd eyefinity technology is here, featuring all-new support for stereo 3d, universal bezel compensation and brand new display configurations. face it: the best just got better. armed with the new pci express 3.0 standard, multi-gpu configurations with amd crossfire™ technology are just another way to obliterate the competition with the revolutionary amd radeon™ hd 7950. leave no performance behind. get higher clocks and faster gaming with amd powertune technology on amd radeon™ hd 7950 graphics. fold and mine faster than ever with amd app acceleration powered by the unprecedented 28nm gcn architecture. the market isn't ready for 4k video, but radeon™ is. with full support for 3ghz hdmi 1.4a and displayport 1.2 hbr2, the amd radeon™ hd 7950 is set for quad hd.
this is the latest edition of amd's radeon 7950 gpu with boost technology. what this means to the gamer is better fps as the gpu automatically boost too 925mhz when underload to improve the gaming experience.
features:-
- voltage unlocked - great for overclocking with people achieving around 1100-1250mhz core clock!!
- core clock: 850mhz (925mhz boost)
- memory: 3072mb gddr5
- memory clock: 5000mhz (effective)
- memory interface: 384-bit
- processing cores: 1792
- bus type: pci-express 3.0
- display connectors: 1x dual link dvi, 1x hdmi & 2x mini-displayport
- hdcp capable
- directx 11 support
- opengl 3.2 support
- ati crossfire ready
- ati eyefinity technology
- ati avivo hd
- ati stream technology
- ati hd3d technology
- free shipping: buying this product entitles you to free shipping on your entire order!
- amd golden ticket: choose 3 free games: http://www.amd4u.com/radeonrewards/
- free crysis 3: origin download code emailed to you when buying this product.
- crysis3 link: http://www.amd4u.com/neversettlereloaded/index.html
- Warranty: 2 Years
Only £199.99 inc VAT.
order now
___
his hd 7970 iceq x² ghz edition 3072mb gddr5 pci-express graphics card (h797qmc3g2m) @ £259.99 inc vat
hightech information system (his) today announced the launch of his 7970 iceq x² 3gb. this world’s fastest card with single gpu is cooler and quieter with the innovative and performance-leading iceq x² solution. the card also has better oc capability and longer life span with his high quality component.
with iceq x², the card is up to 17 °c cooler than the reference cooler. the super large 2x 8.9cm dual axial fans draws massive amount of cool air to cool the gpu directly. the fan is extremely durable with a life span of up to 50,000 hours. 3x 6mm and 2x 8mm wide heatpipes optimize cooling performance by removing heat from the core area. the extra large 40x47.5mm copper heatsink provides a large area to dissipate heat efficiently. the card also carries memory and mosfet heat sinks to provide extra heat dissipation from these areas. the card also features fan control and monitoring, you are able to read fan speed & asic temperature from ccc or software.
iceq x² is one of the quietest coolers. the card is below 28db when watching movies, surfing facebook, working. the card is quiet in 2d mode and remains quiet whether you are gaming, online socializing, entertaining or working. the card is up to 15db quieter than the reference cooler.
iturbo is your software assistant to control your graphics card to be quiet, cool and experiece overclocking by simply pressing the iturbo button! user friendly overclocking software: cooler, quiter, oc! iturbo's fan control and fan monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly!
press iturbo: oc right away!
with the smart auto overclocking function, users can experience a slight performance boost for selected his graphic cards with just one click!
powerful overclocking software
specification:-
- pci-e 3.0 ready: delivers double the bandwidth per lane of pcie gen2 for faster gpu- cpu
- fastest single gpu graphics card on the planet
- hugely overclockable
- vastly cooler running than previous generation
- quieter running than previous generation
- compute power: 3.5 tflops
- core clock speed: 1000mhz
- primitive rate: 2 prim / clk
- shader architecture: gcn
- stream processors: 32 cu / 2048 alu
- texture units: 128
- rops / z-stencil: 32 / 128
- frame buffer / memory: 3gb gddr5
- memory width / speed: 384 bit / 6000mhz
- load / idle board power: <300w / <3w
- power connectors: 8-pin + 6-pin
- display outputs: 1xdvi + 2x mdp + 1x hdmi
- 2yr Warranty
Only £259.99 inc VAT.
ORDER NOW
Do you have a lot of those HiS 7950 cards left in stock or are you likely to run out soon?
Or is the 9 left listed on the website the last of them?
Great card (the 7950) wish I had 2 of them instead of one of those and a Sapphire (not that the Sapphire isn't a good card but it would look better haha)
I think the 9 left is at the today only price if you click on the item on the homepage it shows 10+ in stock
Exactly the same as you! Then I try to think logically in that it's on the floor under my desk, so I don't ever see.
9 is left at special price.
Total stock is less than 50 left, they shall be gone forever by end of month.
