Another two great products at fantastic prices. Perfect for this time of year for gifts or just to treat yourself to some new hardware!
Limited deal price stock so hurry before they all sell out!
Asus VE228H 22" Widescreen LED Multimedia Monitor - Black @ £109.98 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Only £109.98 inc VAT.
ORDER NOW
Edimax EW-7612UAN 300Mbps High-Gain Wireless-N USB Adapter @ £14.02 inc VAT
Wireless 802.11n Standard (data rates up to 300Mbps*)
Edimax EW-7612UAn has an extended wireless coverage and a higher data transfer rate. It is equipped with the latest wireless technology, which enables it to eliminate wireless dead spots while extending its wireless coverage by 4 times. The EW-7612UAn USB adapter is compatible with IEEE802.11b/g/n wireless standards, and is capable of transferring data at up to 300Mbps when connected to 802.11n wireless devices. The wireless technology in the Edimax EW-7612UAn USB adapter also extends its wireless signal distance, and provides more reliable wireless connections than traditional IEEE802.11b/g wireless networks.
Features a Hardware WPS (Wi-Fi Protected Setup) Button
Wi-Fi Protected Setup (WPS) is a new technology designed to establish a secure wireless network in a fast and easy way. If the wireless device you wish to connect supports WPS, the Edimax EW-7612UAn USB adapter will be able to establish a secure, encrypted WPA data connection with it. All you need to do is press the button, and you are set to go. The Edimax EW-7612UAn USB adapter supports both hardware (button) and software (web page) WPS.
Features Multi-Language EZmax Setup Wizard*
Edimax EW-7612UAn includes an EZmax setup wizard—a setup application available in 16 languages, which will assist you in connecting your new EW-7612UAn USB adapter with wireless networks in no time.
Built-in 3dBi Antenna and Hardwire USB Cable for Improved Wireless Performance
EW-7612UAn not only has a built-in 3dBi high gain antenna, it is also bundled with a free hardwire USB cable for improved wireless performance. When using EW-7612UAn with the hardwire USB cable, it provides better wireless performance at no extra cost.
DMP (Digital Media Player) Compatibility List
• AC Ryan : PlayOn!+/ PlayOn! Mini / PlayOn! Mini+
• Aston: AP-110 / AP-220 / AP-300
• Asus: O!Play HDP-R3 / O!Play HDP-R31
• Brite-View: CinemaTube / HDPrimo / CinemaGo
• DVico: Tvix S1 / Tvix 6620/40N Duo
• Eagreat: M880 / X6 / EG-R6A / EG-R4A / EG-R4B / EG-R3A / EG-R1A / EG-R2A / EG-R1B
• Emtec: V800H / N220 / S800H / V120H
• HiMedia: HD300B / HD300A / HD500B
• Iomega: Screenplay Direct / Screenplay TV link
• MSI: Movie Station
• Mvix: Mvix Ultio
• Nootec: A6 / V8
• Novatron: NTR82 / NTR83
• Popcorn Hour: A200 / C200
• Olevia: ZP-530
• Raidsonic: IcyBox IB-MP305
• Seagate: FreeAgent GoFlex TV / FreeAgent Theatre Plus
• Sumvision: Cyclone MKV / Cyclone MKV (HDD) / Cyclone MKV2
• TerratTec: NOXON M520
• Viewsonic: VMP73
• Western: WDBABX0000NBX / WDBAAN0000NBK
• Xtreamer: Sidewinder / Xtreamer Pro / MK1 (classic)
• Yangxi (Baru): HDPRO+
• Zinwell: ZIN-5005HD
• Viewsonic: VMP73
Only £14.02 inc VAT.
ORDER NOW
Features:-
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- Tilt : +20°~-5°
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
ORDER NOW
• Mvix: Mvix Ultio
• Nootec: A6 / V8
• Olevia: ZP-530
• Viewsonic: VMP73
• Viewsonic: VMP73
ORDER NOW
