**TODAY ONLY! 14/01/2014** Razer Sabertooth Elite Controller & MSI R9 290 Graphics Card
OcUK Staff
4 Feb 2013
Razer Sabertooth Elite Gaming Controller for Xbox 360 & PC @ £59.99 inc VAT
The Razer Sabertooth Elite Gaming Controller for Xbox 360 is the supercharged successor to the award-winning Razer Onza. Now, it has been restructured with even more customizability and control options in an all new, rugged design that doesn’t compromise comfort.
An unprecedented six additional multi-function buttons – two at the shoulders and two removable rocking switches at the bottom of the controller – allow you to react to any situation or enemy instantaneously by putting more power right at your fingertips. The Razer Sabertooth lets you reconfigure your choice of buttons elsewhere on the controller to any of the six multi-function buttons.
With an integrated OLED screen on the Razer Sabertooth, you get ease of customizability over the controller’s multitude of features. From programming the multi-function buttons, to adjusting the analog stick’s sensitivity, and creating profiles, you’ll be setting the controller up just the way you want it.
The best professional gamers are masters of their equipment, not the other way round. The Razer Sabertooth was made to make sure you’re perfectly set up for winning.
- 2 shoulder multi-function buttons (MFB)
- 4 removable multi-function buttons (MFT)
- 4 backlit Hyperesponse action buttons
- OLED screen for feature customization
- Non-slip rubber surface
- Quick-release USB connector
- Detachable 10 ft/3m lightweight braided fiber cable
- Carrying case
- 2.5mm microphone jack
- Approximate size : 110mm / 4.33” (Length) x 154mm / 6.06” (Width) x 57mm / 2.24” (Height)
- Approximate weight: 288g / 0.63 lbs
Only £59.99 inc VAT.
ORDER NOW
_____
MSI Radeon R9 290 "BF4 Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification
Radeon R9 290
- GPU: Hawaii Pro
- Stream Processors: 2560
- Core Speed: 947MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- Cooling: 2-Slot Blower Fan
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 3yr
Features
- DirectX 11.2 Support
- Open GL 4.2 Support
- Dolby TrueHD and DTS-HD Master Audio support
- Crossfire Support upto 4-way: Native software crossfire (No bridge required)
- Gaming @ 4k Resolutions (UltraHD)
- Synergy with next-gen game consoles (Mantle)
- Graphics Core Next (GCN) architecture - optimized from previous generation products
Only £299.99 inc VAT.
ORDER NOW
60 quid though ? You can just buy a normal wired controlled for less than half that and still plug into your pc and it works fine.
Well it's done, might have a go at mining if they are good for that. I'm only getting it as Rome 2 keeps saying not enough graphics memory. I do only have a XFX 6770 1GB.
The deed is done. I feel guilty already because I've had to buy a new PSU too :(
What is your daily hash rate now with the amount of cards you've being buying from us?
I am aiming to have about 5000-6000 hash per day by the time I've finished. :)
I've just grabbed one of these cards.A nice step up from my 7870 I think.
I really don't get this mining lark :\ ..it will be used purely for bf4
All in all, I am now pushing just over 20,000kH/s once it's all up and running :)
My R9 290 will be here later today :) so last night drained my loop and made it CPU only (can't afford new waterblock yet) can't wait.
