**Today Only 14/02/2011** Corsair XMS3 4GB 1600MHz DDR3 & OcUK ATI Radeon 6970 2048MB
22 Aug 2010
Today Only we have 9 units of OcUK ATI Radeon 6970 2048MB GDDR5 PCI-Express Graphics Card for just £251.99 inc. VAT. The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications.
We also have 39 units of Corsair XMS3 4GB DDR3 1600MHz for just £37.19 inc. VAT. This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. Perfect for Sandybridge systems.
OcUK ATI Radeon 6970 2048MB GDDR5 PCI-Express Graphics Card @ £251.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 2 Years
Only £251.99 inc VAT.
ORDER NOW
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) @ £37.19 inc VAT
This 4GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 4GB memory kit (2 x 2GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible (use sub 1.60v)
Only £37.19 inc VAT.
ORDER NOW
[timko];18463191 said:
Free shipping rules state 90days, not 3 calendar months. Today is exactly 90days since Nov 16th and so, depending on the time he joined on that day, his free shipping will be starting today.
This :p
kd
Who deals with RMA requests on the VTX card ? Cant seem to find a website for them, and its offered as 2 years warranty. Is it all done through OcUK ? Is this card reference cooler too ?
"designed specifically to support the Intel Core i5 and Core i7" - so NOT suitable for Core i3?!?
My OcUK Primo Ignition came with this memory and an i3-530 (it now comes with an i3-550 :( and the same memory :confused:), so can I send it back for a full refund as it is obviously "unfit for purpose"?
Actually, it works like a dream - although the PSU did die (taking the mobo with it!) a few months ago - could this have been a memory incompatibility issue?!? :rolleyes:
[In case you're wondering, it was swiftly RMA'd and is now going strong - cheers OcUK Support]
Seriously, why do they specify i5/i7 but not i3? Surely RAM is designed for a chipset (H55/P55/X58/H67/P67/Z68), most of which support i3/i5/i7. I would decipher "specifically...i5/i7" as meaning "socket 1366" (or the SandyBridge equivalent), which is obviously not true - unless I've been sold a pup. :mad:
PS Great price on that i5/i7 memory!
I think they are making people aware of the fact that is an issue for Sandy Bridge (1155) platform. The memory is 1.65V and is fine for i3/i5/i7 1156.
Regarding the i5 550, just bad luck I'm afraid.
