Morning all! If you're looking for a new case or some cooling gaff we've got you sorted today!
NZXT Source 210 Elite Midi Tower Case - Black - ONLY £34.98 inc VAT
NZXT’s Source 210 Elite is here to provide the basic chassis to house your rig and a just a little more to meet your needs. Now with USB 3.0, tool-less features, and an additional 140mm top fan for cooling, it’s modest and contains the essentials for performance. It’s the chassis you can afford, and more.
The Source Series is NZXT’s chassis line designed to be a starting block for first time builders or a stepping stone for those who want to upgrade their rig later on. Each chassis faithfully serves their purpose as an affordable, memorable part of your system building experience; it may just be a keeper.
- 5.25” and 3.5” Screwless Design – Allows easy setup or removal of optical and hard drives.
- USB 3.0 – Provides the most up to date high speed data transfer.
- 2 x 120/140mm fan (1x140mm included)– Maximizes cooling potential.
- Bottom Mounted PSU – Positioned for the most effective PSU ventilation
- Wire Management Support – 20mm space for a neat and easy build
- Aluminum Textured Panel – Accents the chassis for a clean, modern look and feel
- Dual 120mm Front Intake – Takes advantage of front facing HDD bays for excellent airflow
- Maximum Cooling Potential – Eliminate heat by installing up to seven 120mm fans
- Dimensions: (W x H x D) 195mm x 440mm x 495.5mm
- VGA Clearance Maximum: 230mm w/ hard drive, 330mm w/o hard drive
- CPU Heatsink Support: 160mm
- Front Cooling: 2 X 120mm
- Rear Cooling: 1 X 120mm @ 1200rpm (included)
- Top Cooling: 2 X 120/140mm (1x 140mm included)
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 Tool-less External 5.25" Drive Bays / 8 Tool-less Internal 3.5" HDD Drive Bays
- Expansion Slots: 7
- Motherboard Support: ATX, MICRO-ATX
- Front I/O Ports: 1 x Standard Audio/Mic, 1 x USB 3.0,1 x USB 2.0
Only £34.98 inc VAT
CLICK HERE TO ORDER NOW!
_
Antec Kúhler H2O 920 Series 4 High Performance Liquid CPU Cooler (LGA1155 / LGA1156 / LGA1366 / 2011 / AM2 / AM2+ / AM2+ / AM3+) - ONLY £71.99 inc VAT
Antec Kúhler Series 4 offer a higher pressure pump and split flow copper fin radiator design.
These two innovations drop temperatures further than previous versions without changing the price!
Unlike traditional liquid cooling systems, this self-contained unit comes prefilled and requires no maintenance. The dual 120 mm Pulse Width Modulation (PWM) fans and 3rd generation copper coldplate ensure quiet, efficient cooling, while the 49 mm radiator is equipped to handle the highest performing CPUs on the market. Lastly, the included software helps you monitor and control the
Kühler H2O 920’s performance and allows you to customize its stylish RGB LED. Designed to unlock the maximum potential of your CPU, the Antec KÜHLER H2O 920 delivers exceptional cooling when you need it the most.
- Customizable RGB LED for brilliant illumination
- CPU Socket: LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM2+/AM2+/AM3+
- Fan Speed: 700 - 2400 RPM (PWM controlled)
- Radiator Dmensions: 151 x 120 x 49mm
- Fan Dimensions: 120 x 120 x 25mm
- Air Flow: 110 CFM
- 3 Year Warranty
Only £71.99 inc VAT
Only £34.98 inc VAT
_
- Air Flow: 110 CFM
- 3 Year Warranty
Only £71.99 inc VAT
