**Today Only 14/06/2012**MXT Mach Xtreme 2.5" SATA 6GB & Patriot Viper Xtreme 16GB 1600MHz
22 Aug 2010
MXT Mach Xtreme 2.5" SATA 6GB/s MX-DS TURBO PREMIUM Edition 480GB SSD @ £299.99 inc VAT
The MX-DS TURBO PREMIUM Edition Series offers mobile and desktop users groundbreaking computing experience and unparalleled level of read and write performance. The PREMIUM Edition is fine-tuned for IOPS performance. This series of SSDs delivers performance that maximizes the throughput of a SATA III 6Gb/s interface with balanced read/write speeds.
This series supports DuraClass™ and DuraWrite™ technologies. DuraClass™ technology provides best-in-class endurance, performance, and low power consumption. DuraWrite™ technology optimizes writes to the flash memory over conventional controllers increasing the overall endurance and reliability of the complete SSD. Highly intelligent block management and wear leveling also extends the overall endurance.
- NAND Flash: MLC
- Capacity: 480GB
- Interface Type: SATA III
- Form Factor: 2.5"
- Dimension: 99.8 x 69.63 x 9.3 mm (LxWxH)
- Lightweight: 80g
- Max. Read Performance: Up to 555MB/s*
- Max. Write Performance: Up to 510MB/s*
- IOPS: up to 85,000
- Warranty: 3 Years
Only £299.99 inc VAT.
ORDER NOW
Patriot Viper Xtreme 16GB (4x4GB) DDR3 PC3-12800C8 1600MHz Quad Channel Kit (PXQ316G1600LLQK) @ £69.98 inc VAT
Patriot Memory's Viper Xtreme Division 4 Series memory kits are designed specifically for Intel's X79 platform and 2nd generation Core™ processors. Built for extreme overclocking and performance, the Patriot Memory Viper Extreme Division 4 kits features a custom copper and all aluminum heat shield to provide the best thermal protection available.
Available in 8GB and 16GB kits, these modules are engineered to run at PC3-12800 (1600MHz) speeds at 8-9-8-24 timings.
Certified to Intel's strict XMP standards, each module is hand tested for quality, backed by a full-lifetime warranty, and Patriot Memory's industry leading customer service. For Gamers and Enthusiasts looking to get the most out of their systems, The Viper Extreme Division 4 Series memory kit is second to none.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-9-8-24)
- Voltage: 1.55-1.65V
- XMP 1.3 Ready
- Equipped with an extruded aluminum shield to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Only compatible with Intel® X79 chipsets
Only £69.98 inc VAT.
ORDER NOW
The SSD is incorrect speed according to this website: http://www.mx-technology.com/en/product/ssd2.php?sid=34#fragment-19
OCUK stated:
MXT stated:
Max. Read Performance Up to 500MB/s*
Max. Write Performance Up to 420MB/s*
IOPS up to 85,000
Updated: ahhh I found the correct speed as it for 240GB SSD only not for 480GB as you can see the different speed compared between 240GB and 480GB ! So, OCUK had got it wrong speed for this 480GB SSD. See below:
240GB SSD:
Model Name MXSSD3MDSTP-240G
NAND Flash MLC
Capacity 240GB
Interface Type SATA III
Form Factor 2.5"
Dimension 99.8 x 69.63 x 9.3 mm (LxWxH)
Lightweight 80g
Max. Read Performance Up to 555MB/s*
Max. Write Performance Up to 510MB/s*
IOPS up to 85,000
480GB SSD:
Model Name MXSSD3MDSTP-480G
NAND Flash MLC
Capacity 480GB
Form Factor 2.5"
Lightweight 80g
IOPS up to 85,000
You are listing the specs for the Turbo series, not the turbo premium edition. The iops on the turbo premium edition is 85,000
No the turbo premium edition is the same spec here:
NAND Flash MLC
Capacity 480GB
Form Factor 2.5"
Lightweight 80g
IOPS up to 85,000
it didn't say on their site:
lol you ninja edited your post, but still doesn't change the fact that you had the specs for the Turbo edition listed, not the turbo premium edition. The Max Iops on the 480GB turbo is 50,000. On the Premium it's 85,000. These are figures that you changed since I pointed it out.
But you are right about Ocuk having wrongs specs as per the manufacturer website. But normally larger SSD's are faster so maybe the manufacturer website's write speeds should be 520MB/s but they just made a mistake? Or maybe OCuk do have it right and the speeds are the same as the 240GB.
Either way, sometimes what's listed on the the manufacturer website isn't what you get. That's why I am wondering about the 3.5 inch adapters :-)
Can somebody please answer does the MXT drive come with the adapters needed to make the drive fit into a 3.5 inch bay.
Thanks.
Ok, just after getting a reply to my post in the pre-sales queries section of the forum.
These do not come with an adapter :-( which pushes this drive too far over my budget!!
