Edifier Spinnaker 2.0 Speaker System - Black @ £239.99 inc VAT
The award-winning Spinnaker by Edifier is an iconic system, standing 15 inches tall the abstract shape is designed to be visually striking as well as a facilitator to enhance the audio performance. The shape projects sound towards the listener with a 19mm silk domed, front facing tweeter, a 23/4 inch mid-range driver, reinforced with a downward firing 4 inch subwoofer in each satellite. The Spinnaker is Bluetooth enabled, allowing audio connectivity to any Bluetooth device that supports both A2DP and AVRCA profiles for versatile track navigation, play/mute and volume adjustment through the multi-functional dome-shaped remote control. The remote control operates on a 433Mhz radio frequency up to a 10M radius making all control options easily accessible without the disturbance of inanimate objects. An optical and auxiliary input port is also available for connectivity to other external multimedia devices simultaneously. A speaker-output port allows an external subwoofer/speaker to be connected for additional base performance, making the Spinnaker a versatile system for both home and office use.
Frequency response: 68Hz - 20kHz +/-3dB on reference axis
Frequency range: 50Hz - 23kHz -10dB
Crossover frequencies: 135Hz -10dB
Distortion: 0 0.5%
Input sensitivity: 800mV±50mV
Audio input: Bluetooth, Optical, Auxiliary
Audio output: Bass expansion for outboard subwoofer
Adjustment: Wireless remote control
Power supply: Input 100V-240V AC, Output 20V/60W DC
Speaker unit: Treble: 19mm silk dome, Magnetically shielded, 4ohm Midrange: 2¾ inch (70mm), Magnetically shielded, 4ohm Bass: 4 inch (116mm), Magnetically shielded, 6ohm
Dimension: 140mm x 413mm x 189mm (W x H x D)
Weight: 4.3Kg (net) | 5.3Kg (gross)
Total power output: RMS 10W x 2 +10W x 2 + 25W x 2
Only £239.99 inc VAT.
ORDER NOW
______
Creative Sound Blaster Tactic3D Rage USB Gaming Headset @ £49.79 inc VAT
Feel the Rage in your audio!
The Sound Blaster Tactic3D Rage USB Gaming Headset is just what you need if you're a serious gamer. It deliveris superior uncompromised gaming audio that's backed by decades of legendary Sound Blaster expertise.
The headset features SBX Pro Studio audio technologies, which allow you to fully customize every aspect of your headset's audio settings. SBX Surround positions audio in a 360-degree sound stage that's much more realistic than standard 7.1 solutions. Massively powerful 50mm FullSpectrum™ drivers are meticulously tuned to produce the most accurate 3D gaming audio environment available for your PC or Mac. With 16 million colors, the earcups' SB Prism™ LED illumination gives you an almost unlimited choice of colors to represent your team or gaming gear setup.
16 million-color illuminated ear cups
Put on a color that fits your style or mood. Choose from a dizzying 16 million colors to complement your team, rig, or aura.
Affordable USB gaming headset
Enjoy superior, uncompressed audio for your games and entertainment that's affordable, without any compromise in audio quality.
High-quality USB audio cable
Spend more time gaming instead of being in a tangled mess. The high quality braided USB audio cable provides excellent flexibility while minimizing unwieldy tangles.
50mm FullSpectrum drivers
Experience a high-powered, no-holds-barred 3D gaming audio experience with massive bass and detailed highs.
3D surround sound
Free yourself from the limits of physical 7.1 audio. Immerse yourself right in the middle of your game.
Take on a persona
With VoiceFX™, you can match your voice to your game avatar, be it an orc, elf or alien infiltrator. Dont just play your avatar, BE your avatar.
SBX Pro Studio
SBX Pro Studio Suite of effects will transform your audio experience into a High-Definition multimedia adventure.
Accessible on-ear audio controls
Easily adjust your game volume or mute your microphone on the fly. With the rotary volume control dial, you can make faster, more precise volume adjustments.
Only £49.79 inc VAT.
ORDER NOW
Distortion: 0 0.5%
ORDER NOW
______
3D surround sound
Take on a persona
SBX Pro Studio
ORDER NOW
