**Today Only 15/02/2012** Akasa USB 3.0 SuperSpeed Memory Card Reader & OcUK Value 32GB USB Pen
22 Aug 2010
A USB flash pen is always very handy. Today you can get a 32GB USB pen for less than £20! The size is perfect for holding large files which need to be transported quick and easily.
If you regularly use memory cards you will know how important a card reader can be. The Akasa card reader features super fast USB 3.0 technology for USB transfers bundled with a wide range of cards to be read.
Akasa USB 3.0 SuperSpeed Memory Card Reader (Internal header) (AK-ICR-14) @ £14.99 inc VAT
Conveniently positioned at the front of your PC, this SuperSpeed six slot USB 3.0 card reader accepts all popular cards in a single location.
Includes a USB 3.0 port for extra connectivity, easy to install with choice of black or classic-white front fascia panels.
- Up to ten times faster than USB 2.0
- Accepts all popular memory cards
- SDXC compatible
- For 3.5” PC front bay
- Application: 3.5" PC bay
- Memory card slots: 6
- Memory card types: Compact Flash (CF I, CF II, Ultra, Extreme, I-Pro, Ultimate, MD), Memory Stick (MS Pro, MS Pro Duo, Magic Gate, Extreme, Ultra), Secure Digital (SDXC, SDHC, SD, Ultra, Extreme, Elite Pro, High Speed, MMC, MMC Mobile) - 64GByte for SDXC - 32GByte for SDHC, Extreme Digital (X card, Type H, Type M), M2 (Memory Stick Micro M2) microSD (microSDHC, High Capacity)
- Interface: USB 3.0 (2.0/1.1 compatible)
- Data transfer rate: 5Gb/s (USB 3.0)
- LED indication: Power On, Card In & Data Transfer
- Power mode: USB powered
- PC connection: Internal motherboard USB 3.0 connector
- Supported OS: Windows 2000 / XP / VISTA / 7
Only £14.99 inc VAT.
ORDER NOW
OcUK Value 32GB USB Drive Black @ £18.49 inc VAT
OcUK Value PinStripe 32GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
- Push and pull sliding feature
- Enhanced for Windows ReadyBoost
- Includes EasyLock Password Protection Software Trial
- Compatible with Windows 2000, XP, Vista & Windows 7
- Compatible with Mac OS 9 or higher & Linux 2.4.0 or higher
With ports in almost every computer and popping up in cars, DVD and Multimedia players, TV's, Photo Frames and many more, USB drives are now being considered an essential accessory.
Only £18.49 inc VAT.
ORDER NOW
any chance someone over at ocukhq could throw one of them usb drives in a pc to see how they run?
Afraid they are blister pack sealed, so we cannot test them. However you will get around 15MB/s read and about 10MB/s write.
