**Today Only 15/02/2013** BitFenix Alchemy Premium Modding LED & Microsoft Xbox 360 Controller PC
22 Aug 2010
BitFenix Alchemy Premium Modding LED Strip - Connect White 30cm @ £13.19 inc VAT
Part of the BitFenix Alchemy Premium Modding Series, Alchemy LED Strips are the ideal choice when modding inspiration strikes. These precision manufactured LED Strips come with BitFenix TriBright™ LED Technology for the absolute brightest LED strips available. Alchemy LED Strips come in both chainable Connect and waterproof Aqua, and offer a multitude of lengths and colors, enabling you to bring your modding vision to light.
When only the brightest will do, BitFenix TriBright™ LED Technology gives you the industry’s brightest LED strips. TriBright uses independent ICs to power each LED bulb for maximum brightness.
Alchemy LED Strips are made using a precision SMT manufacturing process, which means the highest quality, enhanced current conduction, and prolonged life.
Have a special idea that needs an extra-long length of LED strips? No problem. With Alchemy Connect LED Strips, you can connect as many strips together as you need with the only limitation being your power supply's current.
BitFenix Alchemy LED Strips are backed with high-grade adhesive from 3M™, which makes sure that your LED strips will remain where you left them, even when your computer is being moved around.
- Colour: White
- Length: 30cm
- LEDs: 15
Only £13.19 inc VAT.
ORDER NOW
Microsoft Xbox 360 Controller - PC / Xbox 360 (52A-00005) @ £16.98 inc VAT
The Xbox 360 Controller for Windows works with all Windows based PCs and Xbox 360, delivering a consistent and universal gaming experience. Get a better feel for the game with vibration feedback ensuring riveting game play every time. Part of the new Game Precision Series, the Xbox 360 Controller offers precision, comfort and control that will set the standard for next-generation game controllers. The pad has precise thumb sticks, two pressure-point triggers, and 8-way directional pad for enhanced PC gaming.
- For PC and Xbox 360
- Vibration Feedback
- Ergonomic Design
- Xbox Live Play - Integrated headset jack for PC headsets and Xbox Live play
Only £16.98 inc VAT.
ORDER NOW
yeah I have a wireless adapter to use with it wonder if I'll get any better response from a direct attached one
Technically yes, because there is some input lag with wireless devices.
However the amount you suffer, most people won't even notice.
It only really effects tournament fighting games when milliseconds count.
Using my wireless control happily :)
Ive got a wireless adapter (for PC) for my 360 controller, but i just use a wired 360 controller... great stuff.
