**TODAY ONLY! 15/04/2014** Samsung SyncMaster 27" Widescreen monitor & Samsung 22" Widescreen monito
OcUK Staff
4 Feb 2013
Samsung SyncMaster S27C590H 27" Widescreen Slim Bezel LED Monitor - Black @ £161.99 inc VAT
The ultra-slim design, crystal neck and vivid picture quality of the Samsung LED Monitor Series 5 make it one of the most functional monitors around. You can work and see all your favourite content with its Wide Viewing Angle, which provides natural colour consistently and a contrast ratio that lets you view the monitor from any angle within 178 degrees. And with Magic Upscale and Mega DCR functions, you will get improved picture quality, always. Clear images for a happier you.
The Samsung LED Monitor Series 5 has been developed to give you the best possible view. Unlike other monitors, it features a super-narrow bezel that makes the screen more prominent and means there’s nothing to distract you. This is enhanced by a slim crater depth. Instead of being hidden away, the screen is more visible so you can make the most of it. Viewing is more immersive, with a maximised picture to boosts entertainment or productivity.
the best view from any angle with the Samsung LED Monitor Series 5. Unlike conventional monitors, this Samsung LED Monitor has an extra wide viewing angle of 178 degrees, vertically and horizontally. The wider angle allows you to have the same picture quality from any front angle view. With the additional 8 degrees, the Samsung LED Monitor Series 5 is the perfect display to show movies in front of a large audience or to view other content such as pictures.
Mega DCR delivers new levels of colour and picture quality to your viewing experience with images that are real-to-life. Mega DCR’s contrast ratio shows blacks at their absolute darkest and pristine whites and other colours at their brightest. You will notice a boost in the contrast level and clearer picture clarity. It is like an explosion of colours that makes other screens seem dull in comparison. Enjoy your content with the professionalism it deserves.
Magic Upscale improves image quality to such a level that you will only receive a better picture. Enjoy enhanced image quality no matter how the original picture quality is. Magic Upscale prevents image degradation when scaling up and gives only brilliant and pristine colours and images. And it also makes images on the monitor appear clearer and sharper than on a note pc. Shine with Samsung LED Monitor Series 5.
Specification:-
- Screen size: 27"
- Screen Type: VA Panel
- Resolution: 1920x1080
- Response time: 5ms
- Contrast ratio: Mega DCR (static 1000:1)
- Brightness 300cd/m²
- Viewing Angles: 178/178
- Connectivity: 1x HDMI, 1x VGA, Audio Out
- Speakers: NO
- Colours supported: 16.7 million
- Warranty: 2yr
Only £161.99 inc VAT.
ORDER NOW
_____
Samsung LS22C570HS 22" Widescreen LED Monitor - Glossy Black @ £99.95 inc VAT
Part of Samsung’s LED Monitor Series 5 range, the LS22C570HS is a slim 23.6” monitor with a modern, inspiring style. It has been packed full of technology to provide enhance functionality, giving you improved picture quality and a wide viewing angle.
Series 5 monitors feature Mega Dynamic Contrast Ratio, which delivers vast levels of colours to improve moving image quality, displaying blacks at their darkest and other colours at their brightest. This not only improves picture quality and increases vibrancy, but also helps to deliverer clearer picture clarity. A static contrast ratio of 1000:1 of ensures high quality still images and text.
A wide viewing angle of 178° horizontally and vertically gives you more options of where you can see the screen from without losing image definition. This ensures crisp, clear and perfect colours from almost any angle.
Resolution up to Full HD 1920x1080, ensures that high definition images and video will display in HD, while text looks sharp and well defined. A rapid response time of 5 milliseconds means this monitor can keep up with fast moving action, while the LS22C570HS can show up to 16.7 million colours, to give you the variety that you see in real life.
Samsung’s Magic Upscale technology improves image quality to give you enhanced picture quality, no matter what the resolution of the original image. It prevents image degradation when scaling up and presents brilliant, clean colours and sharp images.
Eco Saving mode will assist you in saving power and money. You can choose from three options (50%, 25% and Power Saving off) to help make power saving easy and tailor your monitor use to suit your needs.
HDMI and VGA inputs give you the ability to connect this monitor to a wide variety of devices, from desktop PCs and laptops to Blu-ray players and games consoles.
Specification:-
- Screen size: 21.5"
- Brightness 250cd/m²
- Speakers: NO
- Dimensions (monitor only): H311.91 x W507.4 x D99.82 mm
- Dimensions (monitor with stand): H407.6 x W507.4 x D189.9 mm
- Warranty: 2yr
Only £99.95 inc VAT.
ORDER NOW
But its a 22"?
But its a 22"?
Part of Samsung’s LED Monitor Series 5 range, the LS22C570HS is a slim 21.5” monitor with a modern, inspiring style. It has been packed full of technology to provide enhance functionality, giving you improved picture quality and a wide viewing angle.
I think anderp was getting a little excited looking at "the women". :D
Some of the screen may be hidden behind the bezel and therefore now viewable, like CRT's were!
Some manufacturers display sizes differently to others... :rolleyes:
Silly LS22C570HS is the model of the woman monitor and its her thats a slim 23.6"
