**Today Only 15/05/2013** Avexir MPower Yellow Series 8GB & IC Diamond 7-Carat Thermal Compound
22 Aug 2010
Today Only!!
Avexir MPower Yellow Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CM) @ £29.99 inc VAT
Avexir Core Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Core Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Mpower series is designed to be a perfect visual match for MSI Mpower mainboards and certain models of Asrock mainboards, giving you a look which shall make you the envy of all your friends.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black/Yellow high performance heatspreaders
- Yellow LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-9-9-24
- Dual Channel Kit: (2x4GB)
- 100% tested at 1600MHz in Intel & AMD based motherboards
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Only £29.99 inc VAT.
ORDER NOW
IC Diamond 7-Carat Thermal Compound (1.5g) @ £3.59 inc VAT
IC Diamond out performs all other compounds in independent user testing amoung the popular brands tested, IC Diamond contains 92% pure syntheic Diamond. Purified synthetic diamond has a thermal conductivity of 2,000-2,500 W/mKL compared to 406-429 W/mK for pure silver. IC Diamond is electrically none-conductive and none-capacitive providing protection for electrical components when used.
IC Diamonds exceptional durability is due to its high bulk loading of micronized diamond particles. Each tube of IC Diamond contains over 92% micronized diamond and ais 94% fully loaded counting other miscellaneous particles. This highly loaded mix (90% + Bulk loading) is recommended by chip manufacturers to limit pump out due to thermal cycling.
IC Diamond is a stand out amonst all compounds by providing both high performance and long term reliability. Lightly loaded or creme type pastes initially provide some preformance, however the effect can be transitory, sometimes only lasterin a couple of weeks or months. You are safe in the knowledge that IC Diamond thermal conductivity lasts forever.
Based on Independent tests IC Diamond performs 2.77°C better than OCZ Freeze, 3.28°C better than Arctic Cooling MX-3, 3.38°C better than Arctic Silver 5 and 4.74°C better than the Intel generic paste.
- Each tube of IC Diamond Thermal grease contains 7 carats of micronized diamond with diamond particle loadings @ 94% by weight. Material loading above 90% is recommended as the best combination of rheological and thermal properties to minimize interface pump out due to thermal cycling.
- Superior bulk conductivity
- Excellent thermal impedance
- Tight particle distributions
- < 40 µ maximum particle diameter
- Silicone free
- Lower viscosity
- Greater stability
- Non capacitive or electrically conductive
Only £3.59 inc VAT.
ORDER NOW
