**Today Only 15/07/2013** Cooler Master Hyper TX3 Evo CPU Cooler & Avexir Venom Series 8GB 2133MHz
22 Aug 2010
Monday is upon us, but don't worry - here are some deals!
Cooler Master Hyper TX3 Evo CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £14.99 inc VAT
Optimized for current and future generation sockets, the Hyper TX3 EVO sees improvement in its Direct Contact heat pipe performance, expanded socket support, and a higher quality 92mm wide-range PWM fan.
- 3 direct contact heat pipes with a base that is engineered to minimize CPU contact gaps–providing excellent heat conduction.
- Option for adding 2nd fan with quick-snap fan brackets to increase cooling performance.
- A mere 17 dBA (minimum speed) is accomplished by utilizing a silent 92mm PWM fan with a wide RPM range.
- Versatile all-in-one mounting solution supporting the latest Intel? LGA 1366 / 1155 and AMD FM1 / AM3+.
- Excellent airflow design with compact heat sink dimension.
- Intel® Socket LGA1366/1156/1155/775 / AMD Socket FM1/AM3+/AM3/AM2+/AM2
- Dimensions: 90 x 79 x 136 mm
- Fan Speed: 800 - 2200 RPM (PWM) ± 10%
- Fan Airflow: 15.7 - 43.1 CFM ± 10%
- Fan Noise: 17 - 30 dBA
- Connector: 4-Pin
Only £14.99 inc VAT.
ORDER NOW
Avexir Venom Series 8GB (2x4GB) DDR3 PC3-17200C9 2133MHz Dual Channel Memory Kit (AVD3U21330904G-2CIG) - Green Light @ £71.99 inc VAT
Avexir Venom Series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. The Venom Series is developed by Avexir R&D team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.
Avexir Core Venom Series is extremely unique as its most likely the only RAM in the world which uses strobe/pulsating LED's. Even more unique is that the Venom series are green in colour, making them look absolutely amazing, plus a perfect match for Gigabyte Sniper boards.
Avexir strictly adheres to quality standards set by JEDEC (the Joint Electron Devices Engineering Council) and ISO9001.
With 100% hand-tested extensively in multiple PC major-brand motherboard environments at its rated speed, Avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.
Features:
- Black PCB
- Black high performance heatspreaders
- Green LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 9-11-10-27
- Dual Channel Kit: (2x4GB)
- 100% tested at 2133MHz in Intel & AMD based motherboards
- Lifetime Warranty
Only £71.99 inc VAT.
ORDER NOW
