**Today Only 15/12/2010** Logitech G700 Wireless Gaming Mouse & Arctic Cooling Freezer 7 Pro Rev 2 C
22 Aug 2010
Today Only, we have 15 units of Logitech G700 Wireless Gaming Mouse for only £59.97 inc. VAT.The G700 keeps you comfortable, in control and deep into your game. The natural curves fit your hand for epic levels of comfort, so you can keep gaming for as long as you want.
We also have 25 units of Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler for just £15.98 inc. VAT. The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient.
Logitech G700 Wireless Gaming Mouse (910-001759) @ £59.97 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Only £59.97 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) @ £15.98 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Only £15.98 inc VAT.
ORDER NOW
In the market for a new, cheap cooler; does the Arctic Cooling one allow you to fit a 120mm fan or do I have to stick with the stock 92mm?
The stock fan is inside a plastic case that clips onto the heatsink so there are no screw holes. So no, you can't unfortunately.
But a 120mm is not needed as this provides great cooling... keeps my i3 540 3.06GHz @ 4.2GHz at 27-28 degrees idle, and 46 maximum whilst playing WoW on ultra so it's great value for money.
I swear you are reading my mind. This is the second time a product I've been interested in getting has been on sale. I've been after a new CPU cooler since my stock one has started to make a buzzing noise. I think it's been knocked out of whack and is brushing against the housing.
A quick question. How big is the cooler? There are no measurements or scale so is it exceptionally large. I have a medium sized case, but I don't want to get it and have it not fit.
Also on the home page it says "FREE shipping", but when you go to the checkout they all cost money (except collect at store of course). How does that work?
Thanks.
I thought as much. Why put it on the home page without any indication as to those restrictions? I bet the vast majority of people visiting the Web site will not meet those criteria. I think it should be amended to explain who is eligible, or be removed all together. It's just confusing.
Any way I've looked up the size and it should fit my case (fingers crossed). I'm going to buy an 80mm case fan too to expel the hot air from the case. My current cooler funnels it out the side panel.
Never actually noticed it say free shipping on the homepage, but if it does it should really link to that forum post.
*Edit* Ahh i see where it says free shipping now , very misleading not too mention the loyal forum members part (although I've highlighted that once b4 ;) )
The free shipping criteria actually stops my impulse buying, that G700 is so tempting at that price but the added shipping just stops me from clicking "Go to Checkout" lol :p
I hope they are more careful in the future. I got that cooler after all (as well as a couple other things), but since they were small and light the shipping was quite cheap (lust under £5 for 2nd class, but I shelled out an extra pound or so for 1st class).
For large items the shipping can be a real issue. That's why I can't wait until I can get free shipping (I won't spam to reach the number though).
