**TODAY ONLY! 16/01/2014** Impactics C3LH-B & CM Storm Scout II
OcUK Staff
4 Feb 2013
Impactics C3LH-B Mini-ITX Case - Black @ £78.95 inc VAT
Simple, silent, smart!
When you want to build an ultra-compact PC there is normally a very limited choice of chassis options. Options for a high quality chassis is severely limited because of the design as a complete computer, many specifications can hardly be influenced. The German manufacturer Impactics is proposing exactly this gap and offers a system with high flexibility.
In essence it is a special case, which is designed for passive cooling. For this purpose, Impactics have the option for multiple coolers for various motherboards, which transfer the heat via heat pipes to the chassis housing where it is distributed to the lateral fins. Thanks to this modular system of interchangeable components this the ultimate mini-PC chassis.
The case is ulta-compact design but can house a slim optical and a 2.5-HDD. Thus, it requires minimal storage space and can be used almost anywhere.
The advantage of this unique solution is that the radiator fins do not require any active cooling and therefore generates no noise.
The insides of the cooling fins are each equipped with two movable mounting rails. These are the heat-pipe coupling to produce in this way the contact between CPU and cooler fins.
- Dimensions (with feet): 262 x 88 x 237 mm (WxHxD)
- Dimensions (without feet): 262 x 80 x 237 mm (WxHxD)
- Material: Aluminum (front fins), steel (housing)
- Weight: 2.44 kg
- Drives (optional): 1 x 5.25 inch slim (external) / 1 x 2.5-inch Slim (internal)
- Cooling system: heat pipes (optional) and cooling fins
- AC adapter (optional): external / internal
Only £78.95 inc VAT.
ORDER NOW
______
CM Storm Scout II Advanced Gaming Case - Gun Metal @ £64.99 inc VAT
CM Storm Scout 2 Advanced is the upgraded edition of Scout 2. It supports up to 9 fans, including two pre-installed 120mm red LED fans in the front for optimized cooling. It features improved steel reinforced carrying handles, bolted to the core structure. The top console has been upgraded to USB 3.0 for high power charging and lightning fast file transfers, and can be hidden and protected from dusty battlefields, friendly fire and melee attacks behind a slide cover. The 1st HDD cage can be removed, to support monster VGAs like the NVIDIA GTX 690 and AMD HD 7990, turning it into a powerful Battlestation.
- Ergonomic steel reinforced carrying handles
- Dual USB 3.0 support for 10x faster file transfer and high current smart phone / tablet charging (~1A)
- Supports up to 3 ODDs (tool-less), 7 HDDs and 4 SSDs for increased expandability
- Supports up to 9 fans, including two 120mm fans on the acrylic side panel window
- Two pre-installed 120mm red LED fans behind the front mesh panel for optimized airflow
- Top panel LED switch to disable the LEDs of front LED lit case fans at night
- Supports all high-end graphics cards up to 399mm / 15.7 inch with the 1st HDD cage removed
- Dust filters for PSU (slide out) and front panel
- Materials: Appearance: Polymer, Coated Steel Mesh and Body
- Dimensions (W x H x D): 230 x 513 x 517.5mm / 9.1 x 20.2 x 20.5 inch
- Net Weight: 8.56 kg / 18.87 lbs
- Motherboard Type: Micro-ATX, ATX
- 5.25" Drive Bays: 3 (exposed)
- 3.5" Drive Bays: 7 (hidden)
- 2.5" Drive Bays: 4 (converted from 3.5" drive bays)
- I/O Panel: USB 3.0 x 2 (int.), USB 2.0 x 2, Mic x 1, Audio x 1 (supports AC97 / HD Audio)
- Expansion Slots: 7
- Cooling System: Top: 120mm fan x 2 (optional)
- Front: 120mm red LED fan x 2 (with LED on/off function)
- Rear: 120mm black fan x 1
- Bottom: 120mm fan x 1 (optional)
- Side: 120mm fan x 2 (optional)
- HDD cage: 120mm fan x 1 (optional)
- Power Supply Type: Standard ATX PS2
- Maximum Compatibility: VGA card length: 287mm / 11.3 inch (with HDD cage); 399mm / 15.7 inch (without HDD cage)
- CPU cooler height: 162mm / 6.4 inch
Only £64.99 inc VAT.
ORDER NOW
