Today Only, we have 10 units of Lian Li PC-A04B Aluminium Midi-Tower Case for only £76.98 inc. VAT. Small or big? The PC-A04 is a small space with big features! With room for three 120mm fans, seven 3.5" Hard Drives and even space for graphics cards up to 370mm in length.
We also have 15 units of MSI P67A-C45 Intel P67 Motherboard for just £84.98 inc. VAT. This is the entry level motherboard from MSI built with military class components featuring 4x USB 3.0, 2x SATA 6GB/s and much more.
Lian Li PC-A04B Aluminium Midi-Tower Case - Black ** UK Exclusive ** @ £76.98 inc VAT
Small or big? The PC-A04 is a small space with big features! With room for three 120mm fans, seven 3.5" Hard Drives and even space for graphics cards up to 370mm in length. The chassis is made entirely from Aluminium and all external panels are brushed for an amazing finish. With USB3.0 and e-SATA support these case will encompass your needs for years to come.
- Dimensions: 188 x 386 x 460mm (W x H x D)
- Aluminium Material
- 2 x 5.25" Drive Bays
- 1 x 2.5" Drive Bay
- 7 x 3.5" Drive Bays
- Expansion Slots: 4
- Motherboard Compatibility: MicroATX / Mini-ITX
- Front System: 120mm Fan x 2
- Top System: 120mm Fan x 1
- I/O Ports: 1 x USB3.0 / 1 x USB2.0 / 1 x e-SATA / HD Audio
- Max GPU Size: 370mm
Only £76.98 inc VAT.
ORDER NOW
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) @ £84.98 inc VAT
Key Features
Military Class
- Super Ferrite Choke - 30% Higher Current Capacity, whistle-free design
- Solid Capacitor - 10 Year Ultra-Long Lifetime, low ESR
OC Genie 2
- Intelligent detect hardware settings
- Automatically overclock CPU and Memory in 1 second
- Increase CPU speed up to 4.GHz
Click BIOS
- New UEFI BIOS with graphical menu
- User Friendly Mouse or Keyboard Controlled Interface
- Multi-language support
Specifications
- Intel LGA1155 Socket
- Intel 2nd Generation Core i7/i5/i3 & Pentium/Celeron Support
- 4x DIMMs with support for DDR3 1133/1066 up to 16GB MAX
- 1x PCI-Express x16 Slot
- 3x PCI-Express x1 Slots
- 3x PCI Slots
- 4x SATA 3Gb/s ports with RAID
- 2x SATA 6Gb/s ports with RAID
- 2x eSATA ports
- 4x USB 3.0 ports
- 10x USB 2.0 ports
- 2x IEEE 1394 Fire
- 8 Channel HD Audio with THX TruStudio Pro
- Gigabit LAN
- Dual BIOS
- Potential Sandybridge issue:
- In some cases, motherboards featuring the 6 Series Chipset (P67 & H67) that have Sata devices connected to ports 2-5 could potentially degrade over time.
- Motherboards with devices connected to Ports 0 & 1 remain unaffected or using the 6Gb/s ports.
- Please note if your board is affected by the above issues, your statutory rights remain to RMA the board.
- Tests have found that under 5% of boards are affected.
- PLEASE NOTE THERE IS NO POTENTIAL ISSUE TO SANDYBRIDGE PROCESSORS
Only £84.98 inc VAT.
ORDER NOW
ORDER NOW
Key Features
Military Class
OC Genie 2
Click BIOS
Specifications
- 3x PCI Slots
- 2x eSATA ports
- 4x USB 3.0 ports
- 10x USB 2.0 ports
- 2x IEEE 1394 Fire
- Gigabit LAN
- Dual BIOS
ORDER NOW
