**TODAY ONLY! 16/04/2015** Aerocool Xpredator Cube (Red/Gold) & Busbi 2 x 16GB USB 2.0 Twin Pack
OcUK Staff
4 Feb 2013
Aerocool Xpredator Cube Micro-ATX Case Red/Gold @ £56.99 inc VAT
Finally, the cube styled case of the popular Aerocool gaming case model "XPredator" has hit the market. Not only it possesses the original XPredators look, it is also more compact and easier for transportation. This case was designed for everyone including heavy gamers who will find this case incredible for its excellent airflow performance and watercooling abilities.
Specifications:-
- Dimensions: 280 x 380 x 350 mm (W x H x D)
- Weight: 7.2 kg
- Material: steel (0.7 mm), plastic
- Color: Gold,Red
- Form Factor: Mini-ITX, Micro-ATX
- Total fan possible:
- 1x 200 mm / 2x 140/120 mm (front)
- 2x 140/120 mm (rear)
- 2x 140/120 mm (cover)
- Thereof pre-installed:
- 1x 200 mm (front; LED)
- 1x 140 mm (rear)
- Radiator Mountings (partial waiver of fan slots):
- 1x max. 280/240 mm (front)
- 2x max. 140/120 mm (rear)
- 1x max. 280/240 mm (cover; do not set 5.25-inch frame)
- Fan control: 2 channels, max. each 15 W, continuously
- Filters: front, power supply (removable)
- Drive Bays:
- 1x 5.25 inch (external)
- 3x 3.5 inch (internal; tools)
- 5x 2.5 inch (internal; 3x instead of 3.5 inches, 2x on 5.25-inch frame)
- Power supply: 1x Standard ATX (optional)
- Expansion Slots: 4
- I / O Panel:
- 2x USB 3.0 (internal connector)
- 1x per Audio In / Out
- Maximum PSU length: 320 mm
- Maximum video card length: 320 mm (with front fan)
- Maximum video card length: 345 mm (without front fan)
- Maximum CPU cooler height: 165 mm (with lid fans)
- Maximum CPU cooler height: 190 mm (without lid fan)
Only £56.99 inc VAT.
ORDER NOW
_____
Busbi 2 x 16GB USB 2.0 Flash Drive Silver Twin Pack (BUS16LITER2TWINSLV) @ £5.99 inc VAT
Features:
Easy to use, easy to store, fully plug and play
Store and share your favourite music, photo, video and files with your family and friends
Compact in size with capped design
High speed USB 2.0 interface
LED indicator whilst powered and on activity
Dimensions - 67 x 21 x 7mm
Weight - 35g each
Only £5.99 inc VAT.
ORDER NOW
The usb drives aren't the quickest at writing but I gave one to the missus for her work laptop backup and one to my mother and as long as your prepared to wait while it transfers files they're fine especially at £3 each
True you have to go make a cup of tea while waiting for the very slow transfers speeds to do its job
