***Today Only 16/07/2012*** BitFenix Spectre PRO 120mm Fan Blue LED & Gelid Tranquillo CPU Cooler
22 Mar 2011
Cheshire
BitFenix Spectre PRO 120mm Fan Blue LED - Black @ £8.50 inc VAT
Following the success of our Spectre™ LED Fan Series, Spectre Pro™ LED ups the ante with an all-new design and enhanced performance. The high pressure and CFM design produces wicked cooling and is also perfect for watercooling setups. Its dual frame construction not only looks great, but also helps to dampen vibrations that cause unnecessary noise. Reinforced fan blades prevent warping at high RPM levels, while focused airflow ensures cool air can reach all of your installed components. With FDB technology for low noise and long life, multiple color options, and on-the-fly light switching, Spectre Pro LED is the new gold standard in performance case fans.
Harness the fury with the Spectre Pro LED Fan Series.
- Dimensions (mm): 120x120x25mm
- Current (A): 0.18A ±10%
- Speed (RPM): 1200 RPM ±10%
- Air Flow (CFM): 56.22 CFM ±10%
- Air Pressure (mmH2O): 1.24 mmH2O
- Noise (dB-A): 18.9 dB(A)
- Colour: Blue
Was £11.99 Inc. VAT
Only £8.50 Inc. VAT
ORDER NOW
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) @ £20.99 inc VAT
The tower CPU Cooler “Tranquillo” uses 4 power heat pipes and a special heat pipe constellation to achieve best heat transfer from CPU core to the aluminium fins in its class. After precise software simulation and calculation during the development stage a unique heat sink shape was created to lower air flow resistance as much as possible.
A silent 120mm fan with the intelligent GELID PWM (Pulse Width Module) control has been chosen to make this heat sink more valuable. The fan blades were optimised to guarantee high airflow while running silently. The intelligent GELID PWM curve keeps the fan silent when no necessary cooling is needed and accelerates the fan speed whenever additional cooling is needed. The multi-award winning high performance GC-2 thermal compound is already included in the package.
Additionally mounting clips for AMD 754/ 939/ 940/ AM2/ AM2+ and for Intel 775, 1366 and latest 1156 sockets as same as back plates for Intel LGA 775, Core i5 and Core i7 boards are all included.
- Socket Compatibility: 754 / 939 / 940 / AM2 / AM2+ / AM3 / LGA775 / LGA1155 / LGA1156 / LGA1366
- Dimensions: 74 x 125 x 153mm (L x W x H)
- Fan Speed: 750 - 1500 RPM
- Air Flow: 58 CFM
- Noise Level: 12-25.5 dBA
- Weight 645g
- 5 Year Warranty
Was £25.99 Inc. VAT
Only £20.99 Inc. VAT
ORDER NOW
Would the Gelid be better than the Arctic Cooling Freezer Extreme?
I've been watercooled for too long :D
I've got a Gelid and really rate it in terms of it's ease of fitting, noise level and I'm more than happy with it's cooling performance.
Great price!
the NZXT 120mm fans are the ony ones showing for 120mm fans, methinks that whoever added them has broken the website somewhat :D
