Razer Naga 2014 Expert MMO Gaming Mouse @ £59.99 inc VAT
The Razer Naga's revolutionary 12 button thumb grid has been outfitted with mechanical switches to give you tactile and audible feedback, so you can be assured of every actuation.
The design of the thumb grid itself has also been improved with an all-new concave shape to allow each button to stand out individually. This allows for blind-find so you stay focused on the game, letting your instincts and reflexes lead you to victory.
The scroll wheel on the Razer Naga now goes left and right, as well as up, down and in for more buttons at your disposal, whether for destroying games or navigating a lengthy forum for the best MMO strats.
This iteration of the Razer Naga features an all-new one-size-fits-all ergonomic form factor to ensure your hand fits snugly for maximum comfort. Its size is perfectly crafted for all hand shapes and is still light enough to be easily lifted by low-sense MMO players.
Features:-
- Total of 19 MMO optimized programmable buttons
- 12 button mechanical thumb grid
- Tilt click scroll wheel
- 8200dpi 4G laser sensor
- Razer Synapse 2.0 enabled
- Green LED backlighting
- 1000Hz Ultrapolling
- Up to 200 inches per second /50g acceleration
- Zero-acoustic Ultraslick mouse feet
- 7 foot/2.1m braided fibre cable
Specification:-
- Movement Technology: Optical (Laser)
- Programmable Buttons: 19
- Scroll Wheel: 4 Directional Tilt Wheel
- Optical Sensor: 8200dpi
- Max. Acceleration: 50g
- Max. Speed: 200ips
- Ultrapolling: 1000Hz
- Interface: USB
- Cable Type: 2.1m braided fibre cable
- Compatible OS:
- Windows XP
- Windows Vista
- Windows 7
- Windows 8
- Mac OS X (v10.6-10.8)
- Product Width: 75mm
- Product Length: 119mm
- Product Weight: 43mm
Package Contents:
- Mouse
- Quick-start guide
- Razer Sticker
- Confirmation of Razer (Razer Certificate)
Only £59.99 inc VAT.
ORDER NOW
_____
Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) @ £91.99 inc VAT
Direct Airflow Path™ cooling for revolutionary performance.
The unconventional design of Carbide Series Air 540 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way. The included custom Air Series AF140L intake and exhaust fans provide great airflow performance at lower noise levels than typical case fans. And, you can mount up to six 120mm or five 140mm fans, with 280mm top radiator support and room for a 360mm radiator on the front panel.
Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. The tinted, oversized flush-mount side window lets you show off your work.
Outstanding Cooling
Our Direct Airflow Path™ design utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, memory, and other PCI-E components without your drives or power supply getting in the way.
Quieter Operation
Carbide Series Air 540 includes 140mm Corsair Air Series AF140L intake and exhaust fans. The AF140L is based on the award-winning AF140 and provides great airflow performance at lower noise levels than typical case fans. The easy access, low-restriction dust filters are easy to maintain.
Ideal for Advanced Air Cooling and Water Cooling
You can mount up to six 120mm or five 140mm fans, or install a 240mm or 280mm top radiator and a 240mm, 280mm, or even 360mm radiator on the front panel. Corsair’s innovative cable routing system gives you more options for hiding pumps and tubing out of the way.
Built for Builders
Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. You get tool-free PCI-E and storage installation, two internal hot-swap drive bays, and more features for making assembly, upgrades, and maintenance quick and easy. And, the tinted, oversized flush-mount side window lets you show off your work.
About Corsair Carbide Series PC Cases
Corsair Carbide Series PC cases have the high-end features you need, and nothing you don’t. Designed to be the foundation of awesome yet approachable PCs, they combine the latest technology and ergonomic innovations with lots of room to build and expand, and amazing cooling potential.
Technical Specifications
• ATX, Micro ATX, E-ATX, and Mini ITX compatible
• Dual-chamber Direct Airflow Path™ design for outstanding cooling potential
• Clever, space-saving design still offers lots of internal volume
• Includes three High Performance Air Series AF140L fans for better, quieter cooling
• Tons of expansion room for high performance air cooling and liquid cooling
• Full side panel window
• Front dust filter
• Black interior
• Cable routing cutouts with rubber grommets
• CPU cutout in motherboard tray for easy CPU cooler swap-out
• Dual front USB 3.0 ports with internal connector
• Headphone, Microphone front ports
• Eight expansion slots for quad GPU installations
• Fan Mount Locations:
• Front: 2 x 140mm (included), 3 x 120mm (pre-spaced for radiators)
• Top: 2 x 140mm or 2 x 120mm (pre-spaced for radiators)
• Rear: 1 x 140mm (included) or 1 x 120mm
• Drive Bays(x2) 5.25”
• Dual 3.5” hot swap bays
• Four 2.5” tool-free SSD drive cages
• Maximum GPU Length 320mm
• Maximum CPU Cooler Height 170mm
• Maximum PSU length 200mm
• Dimensions: 415mm x 332mm x 458mm
Only £91.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- Interface: USB
- Compatible OS:
- Windows XP
- Windows Vista
- Windows 7
- Windows 8
Package Contents:
- Mouse
- Quick-start guide
- Razer Sticker
ORDER NOW
_____
Outstanding Cooling
Quieter Operation
Built for Builders
• Front dust filter
• Black interior
ORDER NOW
