**TODAY ONLY! 16/10/2013** MSI GeForce GTX680 & Patriot Intel Extreme Masters 8GB
OcUK Staff
4 Feb 2013
Time for an upgrade? Yeeeeeeeeeeeeeeeees it is.
MSI GeForce GTX 680 Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
This MSI GTX 680 Power Edition is almost identical to the record winning MSI GTX 680 Lightning, but here at OcUK we consider this card to be even better than the Lightning for two main reasons. The first being that this card cost far less, but the second that this card has Dual DVI connectivity.
Very limited stock and a crazy price!
Features:-
- GPU Reactor
- Xtreme Thermal
- Military Class III Components
- Triple Overvoltage: adjust the voltage of GPU, memory and VDDCI to unleash the potential of graphics card
- Offer 16 degree cooler and 6.7dB quieter than reference product
- Enhanced PWM Design: provide higher overclocking capability and better stability in peak load
Specification:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1084MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2038MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x Dual-Link DVI-I, 1x DVI, 1x HDMI & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Card Dimensions: 270*111.15*38.75 mm
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
Only £239.99 inc VAT.
ORDER NOW
___
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) @ £49.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Only £49.99 inc VAT.
ORDER NOW
just got the 7970 matrix platinum on daily offer for £220:D, which one of these cards are better in general ?
Pretty close i think. This 680 would easily surpass the 770, but so does the matrix 7970 overclocked.
It comes down to how overclockable the one you receive is I think.
AFAIK the cooler on the matrix 7970 is quieter than pe edition; but we're talking triple slot v double.
in thinking about buying the Corsair 540 air case so i can overclock it without getting really high temperatures, is there any other good cases arround £100-£140?
ive been eying the fractal design xl r2 for a long time... or r4 is midtower.
