TODAY ONLY 16th JULY 2011 - OcUK 22" LCD MONITOR & 8GB DDR3 GENESIS GREY MEMORY
11 Dec 2005
Cheshire
Today Only we have 50 units of the fantastic OcUK V-Line 22" LCD monitor, with crisp image quality and a 1080P resolution, this is a bargain at only £83.99 inc VAT!
We also have 100 units of the Kingston Genesis Grey 8GB 1600MHz C9 memory kit. Perfect for any high end Sandybridge or AMD 990FX setup. With a high memory speed and capacity you can be assured of lightning quick performance and at only £49.98 inc VAT, you cannot miss this!
OcUK V-Line 221V2SB 22" Widescreen LCD Monitor - Black @ £83.99 inc VAT
You want the LCD flat display with the highest contrast and most vibrant images. Philips advanced video processing combined with unique extreme dimming and backlight-boosting technology results in vibrant images. SmartContrast will increase the contrast with excellent black level and accurate rendition of dark shades and colours. It gives a bright, lifelike picture with high contrast and vibrant colours.
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future-proof as it supports 1080p signals from all sources, including the most recent sources such as Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colours.
With sustainability as a strategic driver of its business, Philips is committed to using eco-friendly materials across its new product range. Lead-free materials are used across the range. All body plastic parts, metal chassis parts and packing material uses 100% recyclable material. A substantial reduction in mercury content in lamps has been achieved. We strictly adhere to RoHs standards which ensure that all hazardous material is removed.
On-Off response time is the period required for a liquid crystal cell to go from active (black) to inactive (white) and back to active (black) again. It is measured in milliseconds. Faster is better: lower response time means faster transitions and, therefore, results in fewer visible image artefacts in the display of transition of texts and graphics. On-Off response time is a more important measure in the display of business content like documents, graphs and photos. This monitors sports a 5ms ON/OFF response time making its grey-to-grey response time 2ms.
Adjustable tilt is backward and forward movement of a screen on its base to achieve custom positioning for an ideal viewing angle and more comfort for people who spend long hours working on the computer.
Philips easy picture format control on OSD switches from the 4:3 aspect ratio to the widescreen mode and back again to match the display's aspect ratio with your content; it allows you to work with wide documents without scrolling or viewing widescreen media in the widescreen mode and gives you distortion-free, native mode display of 4:3 ratio content.
Philips designs and produces display products in compliance with strict Restriction of Hazardous Substances (RoHS) standards that restrict lead and other toxic substances that can harm the environment.
Features:-
- LCD panel type: TFT-LCD
- Panel Size: 21.5 inch/54.61 cm
- Aspect ratio: 16:9
- Pixel pitch: 0.248 x 0.248 mm
- Brightness: 250 cd/m²
- SmartContrast: 300,000:1
- Response time (typical): 2 ms
- Inputs: 1x Analogue & 1x DVI-D
- Optimum resolution: 1920 x 1080 @ 60 Hz
- Viewing angle: 176º (H)/170º (V), @ C/R > 5
- Display colours: 16.7 M
- Scanning Frequency: 30–83 kHz (H)/56–75 Hz (V)
- sRGB
- 3yr On-Site Warranty
Only £83.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £49.98 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 9-9-9-27 2N
Capacity: 8GB (4GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.50-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £49.98 inc VAT.
ORDER NOW
I never did get a reply from the other thread regarding this ram. I was told by one of your guys it'd be stable at 1600 at 1.5v for sandybridge but they never replied to guarantee so.
If its rock solid at 1.5v 1600mhz then great, but if not its not a lot of good for SB!
Need to know before purchase please :)
Can you get that monitor in white to go with the Zigmatek Midgard White Knight case I got off you last week?:D Not kidding by the way Ocuk, oh and you dont have a single white monitor in stock.:(
The memory is great, on my oced amd system it is stable at 7.7.7.20 @1333MHz @1.5V and at 9.9.9.24 @1666MHz @1.6V. Performance seems more or less the same for either settings.
I would be mad to get another 8gb tempted tho:D. Didn't even need 8 just for 'future proofing'.
