**Today Only 17/01/2011** OcUK Exclusive Corsair Vengeance 4GB 1600MHz DDR3 & HIS ATI Radeon HD 6970
22 Aug 2010
Today Only, we have 20 units of HIS ATI Radeon HD 6970 2048MB Graphics Card for only £257.99 inc. VAT. The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications.
We also have a UK exclusive on 20 units of Corsair Vengeance 4GB 1600MHz DDR3 Memory for just £59.99 inc. VAT. The Corsair Vengeance memory has been thoroughly tested with the new Intel Sandybridge CPUs and is 100% compatible. Vengeance memory modules provide users with outstanding memory performance and stability.
HIS ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 500W minimum PSU recommended
- Warranty: 2 Years
Only £257.99 inc VAT.
ORDER NOW
Corsair Vengeance 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ4GX3M3A1600C8) ***OcUK Exclusive*** @ £59.99 inc VAT
CORSAIR high performance Vengeance memory module 4GB (2x2GB) 1600MHz 8-8-8-24, CL8, 1.5V for motherboards using Intel dual channel processors. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel P67 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- 100% tested at 1600MHz in P67-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Perfect for Sandybridge
- *Note these were tri-channel kits which have been broken up and re-tested as dual-channel kits for P67 sandybridge and operate 1.45v-1.55v for Sandybridge setups.
Only £59.99 inc VAT.
ORDER NOW
Yeh, amazing deal.
But made me think I hope the damn 6950's don't drop so much in price after I just paid £240+ for one. :o
I paid £210 for my 6950 and for that price it was too good a deal to miss seeing as you could easily unlock the shaders and overclock it to 6970 speeds.
Bearing that in mind, the cheapest 6950s are now around £230 and considering that the 6970 is not exactly the same and has got better memory and slight different power connectors I would go for this for peace of mind more so if you play at high resolutions.
