The Akasa AK-CC4007EP01 Nero 3 CPU cooler supports the lastest LGA2011 socket for any future-proofing you will require.
We have also knocked down our price on the 16GB Vengeance memory kit from Corsair giving you a HUGE £28.00 saving!!
Hurry as deal stock is limited!
Akasa AK-CC4007EP01 Nero 3 CPU Cooler (Socket LGA775/1155/1156/1366/2011/AMD AM2/AM2+/AM3/FM1) @ £23.99 inc VAT
Akasa NERO classic design combines peak performance and near silent operation. A multi-platform cooler designed for the entire range of current Intel and AMD processors. The four high capacity heatpipes utilize direct CPU contact technology for rapid heat transfer. Direct contact eliminates thermal resistance thereby increasing efficiency. High grade aluminium profiled fins ensure optimum heat dissipation. A piano black 120mm PWM fan is mounted using anti-vibration siliconized rubber pins giving whisper quiet cooling.
The product design has been refined to ensure ultra quiet and exceptional cooling for CPU’s up to 150W TDP (Thermal Design Power). It is compatible with the new forthcoming Intel LGA 2011 processors. Akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1155, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets 939, AM2, AM2+ and AM3 are catered for with a cam-lever clip for safe and easy attachment. Performance thermal compound is supplied.
- Four high capacity 6mm heatpipes with direct CPU contact
- Piano black 12cm fan with PWM
- Siliconized rubber fan mounts for enhance ultra quiet performance
- Cooler dimensions: 120 (W) x 86.7 (D) x 160 (H) mm
- Heatsink material: High grade aluminium fins, copper heatpipes
- Heatpipe: 6mm x 4
- Weight: 609g
- Installation: Push pins (Intel LGA775 / 1155 / 1156 / 1366)
- Screws (Intel LGA2011)
- Cam-lever clip (AMD)
- Fan dimension: 120 x 120 x 25mm
- Fan speed: 500-1500 RPM (PWM controlled)
- Max airflow: 50.54 CFM
- Max air pressure: 1.32 mm H2O
- Noise level: 24.6 dB(A)
- Voltage rating: DC 12V
- Bearing type: Sleeve
- Fan life expectancy: 30,000 hours
- Fan connector: 4pin PWM
Only £23.99 inc VAT.
ORDER NOW
Corsair Vengeance Blue 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9B) @ £71.99 inc VAT
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each four module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Four matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
Only £71.99 inc VAT.
ORDER NOW
- Heatpipe: 6mm x 4
- Weight: 609g
ORDER NOW
- Lifetime Warranty
ORDER NOW
