**TODAY ONLY! 17/03/2014** Cooler Master Cosmos SE & Creative Fatal1ty HS-800
OcUK Staff
4 Feb 2013
Cooler Master Cosmos SE Mid Tower Case @ £112.99 inc VAT
More aggressive, more furious - a sporty addition to the COSMOS series - the COSMOS SE. It features a classic supercar design with curved aluminum handles. Behind the front mesh panel are two 120mm blue LED fans with a LED on/off function. Liquid cooling is the name of the game. It supports up to 3 radiators at once - 120 & 280 & 360mm (rear/top/front). The expandability is supports up to 8 HDDs/18 SSDs.
- Superior liquid cooling support: 120, 240, 280 and 360mm radiator; supports 3 radiators at once - 120+280+360mm.
- Supports up to 8 fans, including 4 installed fans – two front 120mm blue LED fans with LED on/off control, one top 140mm fan and one rear 120mm fan.
- Dual Super Speed USB 3.0.
- Great expandability with the support of up to 8 HDDs/18 SSDs
- Supports all high-end VGAs up to 395mm/15.5 inches long and CPU coolers up to 175mm/6.9 inches tall.
- Large cable management space - 34mm.
- Multiple removable dust filters (top, front, bottom, side panel) for improved system maintenance.
- Supercar inspired design with aluminum curve handles.
- Dimension (W / H / D): 263.8 x 569.4 x 524.4 mm
- Weight: 10.8 kg
- Material: Polymer, Steel, Aluminium, Mesh front bezel, Rubber
- Motherboard Type: ATX, Micro ATX, Mini-ITX
- 5.25" Drive Bay: 3
- 3.5" Drive Bay: 8
- 2.5" SATA HDD Bay: 18 (16 converted from 3.5'' Bays)
- I/O Panel: USB3.0 x 2, USB 2.0 x 2, Audio In and Out
Fan Bays: Top 120/140mm fan x 1 (installed)
- Front: 120mm Blue LED fan x 2 (Installed with LED on/off) or 140mm(optional)
- Rear: 120mm fan x 1 (installed)
- Side: 120/140mm fan x 1 (optional)
- HDD Cage: 120mm fan x 2 (optional)
- Expansion Slots: 7+2
- CPU Cooler Heigh: 175 mm
- Power Supply Standard ATX PS2
Only £112.99 inc VAT.
ORDER NOW
_____
Creative Fatal1ty HS-800 Gaming Headset @ £19.99 inc VAT
Creative's Fatal1ty Gamer Headset provides power, precision and comfort for the serious gamer. The ergonomic, lightweight design, with padded velvet earpieces and headband, ensures a comfortable fit during extended gaming sessions. Weapons, positional cues and environmental audio effects sound fantastic through the high-quality drivers, with excellent bass response for powerful explosions. The noise-cancelling microphone transmits voice commands clearly to other team members, and it can be detached for easy storage or to use the headset like regular headphones. In the heat of battle this is the headset that won't leave people stranded - and that's why Johnathan 'Fatal1ty' Wendel, the world's best known pro gamer, uses it.
- Ergonomically designed and acoustically tuned for gaming.
- Padded headband and earpieces for ambient noise exclusion and comfort during long gaming sessions.
- Swivel joint earpiece design adapts to every user.
- Detachable and adjustable noise-cancelling microphone.
- In-line external volume control with microphone on/off.
- Excellent response for voice communications and dynamic in-game audio, with extended bass response for high-impact explosions.
Only £19.99 inc VAT.
ORDER NOW
