Both of these products have been recently featured. If you were at the Gadget Show Live you were able to get a try on the Thrustmaster T500RS racing wheel which is one of the best models around.
The AKASA CPU cooler has also been featured in a recently run competition which had lots of interest, now is your time to buy one at a discount.
Thrustmaster T500 RS Simulator Racing Wheel for PS3 & PC (Licensed for Gran Turismo 5) - With FREE F1 2012 (PC) @ £299.99 inc VAT
H.E.A.R.T. HALLEFFECT ACCURATE TECHNOLOGY™” is the name of the new technology developed by Thrustmaster to reproduce movements made on a product in games. It relies on magnetic – and not mechanical – 3D (HallEffect) sensors, placed in different locations according to the product in question. The precision made possible by the use of this technology is significantly higher than that provided by standard technologies. Another advantage of this system: by eliminating all friction, it guarantees zero mechanical wear, for permanent precision that won’t decrease over time. The level of precision is also enhanced by the absence of any dead zones: even the slightest movement made by the player results in a reaction. Actions in games are therefore more linear, smoother and without any untimely jolts.
- Authentic wheel: 30cm (12”) in diameter with brushed metal central spokes
- Authentic sequential gearshift levers: crafted of brushed metal, attached to the base (so they don’t move with the wheel)
- 17cm in height (for instant access along 1080°)
- Precision, Force Feedback & realistic angle of rotation
- New H.E.A.R.T Hall Effect AccuRate Technology™ on the wheel’s steering:
- Ultra-precise wheel, with 16-bit resolution (65536 values on the steering)!
- Precision that won’t decrease over time (contactless magnetic sensor)
- Force Feedback with industrial motor (Torque 150mNm, 3000rpm, 65W, Ø 52mm/2”)
- Super-powerful, quick responding Force Feedback mechanism
- Rigid motorized stopper, no matter what angle of rotation you select
- Mechanism with large dual belts (fluid and smooth action)
- Angle of rotation adjustable up to 1080° (3 full turns)!
- Realistic pedal set
- Unique design with your choice of 2 positions:
- Floor-mounted position (F1-style)
- Suspended position (GT-style)
- 100% metal, for optimal stability, weight (more than 7 kgs) and resistance
- 3 100% adjustable pedals (spacing between the pedals/height)
- Brake pedal with reinforced and adjustable resistance (included and removable “Realistic Brake” mod)
- Included metal footrest with non-slip grating texture
Only £299.99 inc VAT.
ORDER NOW
Akasa Venom Medusa Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) @ £58.99 inc VAT
Featuring eight high capacity heatpipes for rapid heat transfer, and dual viper fans for epic cooling, the venom medusa is the ultimate CPU cooler from Akasa
Socket type: Intel LGA775, LGA1155, LGA1156, LGA1366 & LGA2011
AMD Socket AM2, AM2+, AM3, AM3+ & FM1
Heatsink material: 8 heatpipes, copper base, aluminium fins
Cooler weight: 1300g
Heatsink dimensions: 163 x 144 x 129.5mm (H x W x D) [12cm Fan]
Fan dimension: 120 x 120 x 25mm
Fan speed: 600-1900 RPM
Fan speed with reduction cable: 500-1400 RPM
Max airflow: 83.63 CFM
Max airflow with reduction cable: 61.62 CFM
Max air pressure: 2.98 mmH2O
Max air pressure with reduction cable: 1.62 mmH2O
Noise level: 6.9-28.9 dB(A)
Noise level with reduction cable: 6.9-22.3 dB(A)
[14cm Fan]
Fan dimensions: 145 x 145 x 25mm
Fan speed: 600-1600 RPM
Fan speed with reduction cable: 500-1000 RPM
Max airflow: 109.55 CFM
Max airflow with reduction cable: 68.47 CFM
Max air pressure: 2.91 mmH2O
Max air pressure with reduction cable: 1.14 mmH2O
Noise level: 7-21.7 dB(A)
Noise level with reduction cable: 7-11.5 dB(A)
Voltage rating: 12V DC
Bearing type: HDB (Hydro Dynamic)
Fan connector: 4pin PWM
Only £58.99 inc VAT.
ORDER NOW
ORDER NOW
[14cm Fan]
ORDER NOW
