Today Only Deals!
Akasa "Vegas" Blue LED strip light - 60cm @ £5.99 inc VAT
Akasa Vegas LED strip light - bright, flexible & extensible
- Bright, flexible and energy efficient LED lighting
- Compact design
- Installation: Adhesive backing
- Voltage:12V
- Length: 60cm
- Number of LEDs: 15
- Power connector: Molex 4 pin
Only £5.99 inc VAT.
ORDER NOW
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) @ £39.95 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-12800 1600MHz CAS 9-9-9-27
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
- Limited Lifetime Warranty
- Sandybridge/Ivybridge compatible
Only £39.95 inc VAT.
ORDER NOW
- Compact design
- Voltage:12V
- Length: 60cm
Only £5.99 inc VAT.
ORDER NOW
- 1.5v VDIMM
ORDER NOW
