**Today Only 17/06/2013** OcUK QH300-IPSM 30" Professional Monitor & Kingston HyperX Blu 16GB 1600MH
22 Aug 2010
Today Only Deals!
OcUK QH300-IPSM 30" Professional Monitor - Midnight Grey @ £640.00 inc VAT
The OcUK QH300-IPSM 30” monitor is the perfect partner for graphics and visual media, where professional grade technology meets revolutionary design. The QH300-IPSM offers huge 2560x1600 WQXGA resolution bringing a whole new dimension to on-screen graphics. The LG S-IPS panel used in the monitor delivers unsurpassed levels of colour saturation which results in image clarity that allows for colours to be easily differentiated to bring unheard of precision and accuracy in visual reproduction. With Shimian’s stylish bezel design the QH300-IPSM won’t leave you disappointed when being admired on your desktop and with its Tilt, Pivot and Swivel features you can adjust the screen in a variety of ways to suit your individual needs. The QH300-IPSM is not just a great looking product with superb features it is also backed up with a 3 year collect and return UK warranty giving the user additional piece of mind in the knowledge that they have support should the encounter any unexpected problems.
Specification:-
- 30” WQXGA S-IPS Panel
- 2560 x 1600 Resolution
- 0.2505 x 0.2505mm Pixel Pitch
- 1000:1 / 1,000,000:1 Dynamic Contrast
- 60Hz
- 6MS Response time
- 370cd/m Brightness
- 178 Degree Horizontal/Vertical Viewing angles
- Inputs – DVI (Dual), VGA, HDMI, Component, Audi In, SPDIF, SVC Port
- Speakers: Stereo 5W + 5W
- 1.07 Billion Colors (10 Bit)
- Vesa compatible
- Software Compatibility – Windows 98/ME/2000/XP/Vista/Win7/Mac OS X
- Dimensions – 680W x 442H x 85D mm
- 3yr Collect and Return Warranty
Only £640.00 inc VAT.
ORDER NOW
Kingston HyperX Blu 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (KHX1600C10D3B1K2/16G) @ £79.99 inc VAT
Kingston's KHX1600C10D3B1K2/16G is a kit of two 1G x 64-bit (8GB) DDR3-1600 CL10 SDRAM (Synchronous DRAM), 2Rx8 memory modules, based on sixteen 512M x 8-bit FBGA components
per module. Total kit capacity is 16GB. Each module kit has been tested to run at DDR3-1600 at a low latency timing of 10-10-10 at 1.65V.The SPD's are programmed to JEDEC standard latency DDR3-1333 timing of 9-9-9. Each 240-pin DIMM uses gold contact fingers. The JEDEC electrical and mechanical specifications are as follows:
- Kingston Blu KHX1600C10D3B1K2/16G
- 16GB Kit - 2x 8GB Modules
- DDR3-1600
- CL10
- 1.5v
- 240pin
Only £79.99 inc VAT.
ORDER NOW
£300 off the usual 30" price-range, but what is an SVC port ?? - bit of a downer that its not got DisplayPort.
Goddamn it! I've got to get some replacement RAM with my RMA of my other RAM and this Kingston would have been perfect, shame that by the time I phone up in the morning they won't be this price anymore :(.
