**Today Only 17/07/2013** Patriot Intel Extreme Masters 8GB & XSPC RayStorm 750 RX240 WC v4 kit
22 Aug 2010
Today only dealios!
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) @ £49.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Only £49.99 inc VAT.
ORDER NOW
XSPC RayStorm 750 RX240 WaterCooling Kit V4 @ £154.80 inc VAT
Kit Contents:
- RayStorm CPU Waterblock
- X2O 750 Bayres/Pump (Black) V4
- RX240 Dual Radiator
- G1/4? to 1/2? Barb (Black Chrome) x6
- Plastic Hose Clip x6
- XSPC 1650rpm 120mm Fan x2
- 120mm Fan Grill (Black) x2
- Intel and AMD RayStorm Brackets
- Socket 1366 and 1155/1154 Backplates
- Socket AM2 and AM3 mounting kit
- 80mm to 120mm Radiator brackets
- 3mm Twin Blue LED with 4Pin Molex
- 5mm Blue LED with 4Pin Molex
- 2 Meters of Clear 7/16" Hose
- 24pin ATX Bridge Tool
- K2 Thermal Paste
Supports:
AMD Sockets AM2, AM2+, AM3, AM3+
Intel Sockets LGA1366, LGA1156, LGA1155, LGA1150, LGA 2011
*Requires mounting holes
Designed for multi-core CPUs
Only £154.80 inc VAT.
ORDER NOW
It's a great offer considering the current prices of RAM, but damn I remember buying the 1866MHz version of that kit on today only for £19.99 lol, should have bought more ^^
Holy Crapolas.....didn't realise RAM had gone that pricey.
bagged two of the 1866 Mhz 16Gb kits of those for £59.99 in Dec....glad I got me two of them then
