Today Only deals
EVGA Intel Z68 SLI (Socket 1155) DDR3 ATX Motherboard (130-SB-E685-KR) @ £69.95 inc VAT
The EVGA Z68 motherboards have arrived! These motherboards based on the latest Intel Express Chipset offer incredible performance and overclocking with Intel Core i5 and Core i7 processors, and with the new Intel Smart Response Technology, users can combine a Solid State Drive with a traditional mechanical drive and receive both high performance and high storage capacity! Intel Smart Response Technology implements a storage I/O caching system to provide users with faster response times for frequently used applications. The entire EVGA Z68 lineup has full support for SATA III/6G and USB 3.0 giving you the latest standards in high performance storage, and a forward thinking true next generation motherboard layout allows you to take control!
Features:-
- Based on Intel Z68 chipset
- Supports Intel Socket 1155 Processors
- 4 x 240-pin DIMM sockets
- Dual Channel DDR3
- Maximum of 16GB of DDR3 2133MHz+
- 1 x PCIe x16/x8, 1 x PCIe x8, 1 x PCIe x4, 3 x PCIe x1
- 0 x UltraDMA133
- 3 x Serial ATA 300MB/sec (3 x Internal + 1x Esata) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
- 2 x Serial ATA 600MB/sec (Internal) with support for RAID 0 and RAID1
- 8 Channel High Definition
- 2 x 10/100/1000
- 10 x USB2.0 ports (6 external + 4 internal headers)
- 2 x USB3.0 ports (2 external + 0 internal headers)
- Audio connector (Line-in, Line-out, MIC)
- FireWire 1394A (1 external/1 internal)
- ATX Form Factor
- Length: 12in - 304.8mm
- Width: 9.6in - 243.84mm
- This product comes with a 3 year limited warranty. Registration is recommended
Only £69.95 inc VAT.
ORDER NOW
Asus VE228HR 22" Widescreen LED Multimedia Monitor - Black @ £107.99 inc VAT
Full HD 1080p Visual Enjoyment Together with HDMI Interface. Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 21.5"(54.6cm) Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.248mm
- Brightness(Max) : 250 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 800000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Video Feature SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 30 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 512.84x385.96x201mm
- Box Dimension(WxHxD): 576x468x148mm
- Weight Net Weight (Esti.): 4.1 kg
- Gross Weight (Esti.): 6.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval Energy Star 5.0, CEL, UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, WEEE, Windows Vista & Windows 7 WHQL
Only £107.99 inc VAT.
ORDER NOW
Features:-
- Dual Channel DDR3
- 0 x UltraDMA133
- 2 x 10/100/1000
- ATX Form Factor
ORDER NOW
Features:-
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- Tilt : +20°~-5°
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
ORDER NOW
