TODAY ONLY 17TH SEPTEMBER - HAZRO 27" MONITOR & AKASA VENOM VOODO COOLER
11 Dec 2005
Cheshire
Today only we have 15 units of the excellent Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Monitor in black for only £479.99 inc VAT! With a multitude of inputs and a crisp 2560 x 1440 resolution, the Hazro HZ27WD is perfect for both professional and gaming use.
We also have 25 units of the Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler for only £39.98 inc VAT. Featuring rubber fan mounts for near silent operation whilst pumping out an epic 83.63 CFM from dual 120mm Viper fans.
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Monitor - Black @ £479.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- Kensignton Security Port
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
- 3yr RTB Warranty (UK customer only)
Only £479.99 inc VAT.
ORDER NOW
Akasa AK-CC4008HP01 Venom Voodoo CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3 @ £39.98 inc VAT
Venom Voodoo, this cooler is definitely rock and roll. Venom Voodoo delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.
The Black cover and copper heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Six high capacity heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium profiled fins. Anti-vibration rubber fan mounting pins provide easy installation and help to eliminate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.
Dual 12cm viper fans giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.
- Dual 120mm PWM fans in killer viper yellow
- Six high capacity 6mm heatpipes with direct CPU contact
- Award winning S-FLOW fan blades provide 30% more airflow
- Rubber fan mounts for easy install and quiet performance
- Fan Dimensions: 120 x 120 x 25mm
- Fan Speed: 600 - 1200 RPM
- Max Airflow: 83.63 CFM
- Noise Level: 6.9 - 28.9dBA
- Cooler dimensions: 131 (W) x 129.5 (D) x 163.5 (H) mm
Only £39.98 inc VAT.
ORDER NOW
Yes, they are not attached in the box, you have to fit them (as you do with 99% of CPU cooler fans)
I was bit surprised you hadn't sold out of the Hazro's, S-IPS, 27", 2560x1440, tons of connections at a good price. I suppose the lack of professional reviews for this display is hurting sales?
