**Today Only 18/01/2012** PowerColor ATI Radeon HD 6970 2048MB & Corsair Dominator 16GB 1866MHz Quad
22 Aug 2010
Today Only we have a LOWEST PRICE IN THE UK on the PowerColor ATI Radeon HD 6970 2048MB graphics card. This powerful card will be able to handle any game of today at high settings.
Grab this amazing Dominator kit and unleash your PC's performance at this great price. Save £30!!!!!!!
PowerColor ATI Radeon HD 6970 2048MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tessellation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5500MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Bus Type: PCI-Express 2.1
- Display Connectors: 1x Dual-Link DVI, 1x Single-Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.1 Support
- ATI CrossFire Ready
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
Only £239.99 inc VAT.
ORDER NOW
Corsair Dominator 16GB (4x4GB) PC3-14900C9 1866MHz Quad Channel Kit (CMP16GX3M4X1866C9) @ £119.99 inc VAT
Dominator memory supports the Intel XMP (Extreme Memory Profile) standard, and each module is individually factory-programmed with an XMP profile indicating supported timing, frequency and voltages. Just enable XMP on your compatible motherboard and you’ll automatically get optimized memory overclocking without having to deal with multiple BIOS settings. Of course, if you’re an experienced overclocker, you can always adjust the settings on your own to push for even higher overclocking performance.
State-of-the-art cooling efficiency is essential for high-performance memory. Our DHX+ technology uses specially designed, high-quality heatsinks and a custom-designed PCB that cools the front and rear of the DRAM chips as well as the printed circuit board itself.
Your performance investment is protected. All of our memory products are backed by a limited lifetime warranty.
Features:-
- Ultra-high performance 16GB (4x 4GB) Domintaor® quad kit with Intel XMP 1.3 profile
- 16GB total capacity provides ample headroom for the most demanding user
- Outrageously fast 1866MHz performance.
- Ultra-low 9-10-9-27 latency
- Intel XMP (Extreme Memory Profile) support
- Limited Lifetime Warranty
- Compatible with Intel X79, Z68 and P67 platforms
- Speed: 1866MHz
- Type: DDR3
- Format: DIMM
- Pin Out: 240
- Pin Voltage: 1.50-1.60V
Only £119.99 inc VAT.
ORDER NOW
A couple of 6970s for the price a single 7970 and it features quiet custom cooling which really makes a difference over reference design - 10c drop in temps with proof here.
Quite temping for 1.5~2 times the performance in CF of a single 580 (depending on your game of choice). This is the lowest price I found as OcUK is £5 cheaper than the nearest competitor.
Would I see a decent performance jump in going from my CF5770s to one of these cards?
Define decent. A 6970 isn't that much faster then a 5870 (look at the reviews) which is what 5770's in xfire equates to but it should give you a smoother gameplay experiance. If you happy with you current setup and you along with crossfire then I would stick with what you have and maybe upgrade to 7770 in crossfire when the time comes.
Well it handles BF3 on high, with textures on ultra. However when there's a lot going on or very large servers the FPS can dip dramatically and makes it annoying. It's usually fine but can get irritating.
Well this feels like a kick in the nuts:eek:
Bought 16gb of that RAM except 1600mhz for £160
Good deal :D
For those that missed out, the Corsair Vengeance 8GB (2x4GB) x2 is yours for £119.98. The default 1.5 volts is easy to obtain for Sandy Bridge motherboards, but may need raising on other types.
As for compatibility, RAM GUY said:
Vengeance modules are made for and tested on Intel Sandy Bridge chipsets and yes the cost of high density memory IC has dropped dramatically in the lest 6 months, however, not all chipsets will support high density memory like what is used on our vengeance modules. They will run at DDR1600 at 1.5 Volts on most MB's but when used on other Chipsets (Other than Intel Sandy Bridge) the memory voltage may need to be 1.6 Volts or higher to run stable.
So bottom line XMS, Dominator Vs Vengeance is like apple to oranges no way to compare really. And you should go by the memory confirurator for your specific MB.
