- 20 Jul 2009
- The bleak North East arm pit of Britain
Today Only we have 8 Units of the NZXT Phantom Enthusiast Full Tower Case - Red/White for just £99.98 inc VAT!
We also have 5 units of the Alpenföhn Matterhorn Shamrock Edition CPU Cooler (Socket LGA775/1155/1156/AM2/AM3/AM3+) for just £44.99 inc VAT!
NZXT Phantom Enthusiast Full Tower Case - Red/White @ £99.98 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £114.98 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Alpenföhn Matterhorn Shamrock Edition CPU Cooler (Socket LGA775/1155/1156/AM2/AM3/AM3+) @ £44.99 inc VAT
Alpenföhn enters the next level and presents the Matterhorn Shamrock CPU Cooler. The brand new 120mm fan cooled tower boasts the highest manufacturing quality, noble black-polished finish and "Shamrock Green" fans making this cooler the best solution for any air cooled system. The Shamrock provides a closed fin design which provides additional stability and channels air through the interior of the heat sink to ensure the heat is taken away efficiently.
- CPU Support: Socket LGA775/1155/1156/AM2/AM3/AM3+
- Close fin spacing on the inside of the heatsink; maximising cooling performance
- Shamrock Green
- Dimensions: 138x123x158mm
- Heatsink Weight: 1kg
- Fan Dimenions: 120x120x25mm
- Fan Speed: 1200 RPM
- Air Movement: 100.55 m³/h
Was £49.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
ORDER NOW
- Shamrock Green
Was £49.99 Inc. VAT
ORDER NOW
