**TODAY ONLY! 18/03/2014** Inno3D GeForce GTX 780Ti & Avexir Blitz 1.1
OcUK Staff
4 Feb 2013
Inno3D GeForce GTX 780Ti iChill OC 3072MB GDDR5 PCI-Express Graphics Card (N78T-1DDN-L5HS) @ £515.99 inc VAT
NVIDIA's latest Geforce 780Ti takes the fight right to the competition in the battle for current worlds fastest single GPU. Packing a fully enabled GK110 GPU with a whopping 2880 cuda cores this card has huge amounts of processing power to enable it to power through any game. Infact the 780 Ti is so impressive, it’s not just cheaper than TITAN, it beats it in performance and takes the crown as the Best Gaming GPU on the Planet.
NVIDIA are supporting the overclocking community even further with an advanced three rail PWM with load balancing, whereas older GTX 780 and Titan pulled all their power through three rails, they did not load balance. 780Ti's new PWM means it can source power from three sources and load balance resulting in the same amount of power from each rail, allowing for more superior overclocks and stability. Here at Overclockers UK we tested this and where we found Titans would top out at 1100-1150MHz core, whereas the 780Ti was able to hit 1200-1300Mhz core over and over again, proving this new PWM not only offers efficiency and stability, but also great overclocking ability. When overclocked this cards performance can be increased by upto a further 30%, making it a truly unstoppable force.
For memory once again here at Overclockers UK we are very impressed to see 3GB of RAM and a 384-Bit interface meaning it can power the latest games even at the highest resolutions and detail settings, making this card the perfect choice for any gamer or overclocker.
780Ti uses the Titan cooling system and this means that even whilst gaming, you can indeed game in silence or at night whilst the rest of the household is asleep and not have to worry about waking up those sleeping.
Specification
GeForce GTX 780Ti
- GPU: GeForce GTX 780Ti (GK110)
- Core Base Clock: 1006MHz
- Core Boost Clock: 1046MHz
- Memory Clock: 7200MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2880
- DirectX 11.2: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Features
- MAX your overclocks with NVIDIA's Power Balancing
- A WHOPPING 2880 CUDA Cores (Fully enabled GK110)
- GPU Boost 2.0 Technology
- TITAN cooling system
Only £515.99 inc VAT.
ORDER NOW
_____
Avexir Blitz 1.1 Original 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2BZ1) @ £89.99 inc VAT
The highly anticipated Blitz 1.1 is specifically designed for gamers and overclockers alike for extreme overclocking performance. The concept of Blitz 1.1 not only extends the fantastic LED light hue from the Core series but also with extraordinary design for heatspreader. The aluminium extrusion technique is deployed on every Blitz 1.1 module and together with its uncompromising design style; the Blitz 1.1 is ready for outstanding gaming and overclocking potential. Blitz also employs self-assembled, adjustable heat sink spreaders; gamers can uninstall external heat sink for ultimate performance.
This is the ordinary and classic design. With rich red and black heat sink as base, the Avexir logo is carved on the side and covered with alabaster white LED on the top. It's like the sharpest sword waiting and readying to fight for the forces from the dark side. This is aligned with Avexir's values, when its ready then we are momentum.
The Avexir brand is an established manufacturer associated with producing top quality, high-end RAM memory. Avexir is one of the only manufactures in which the factories hand check each module when it comes to overclocking and working in dual and quad channel modes. The modules are packed into elegant boxes only when they pass thorough quality control tests on different systems including AMD and Intel processors. Other manufacturers unfortunately don’t do such controlled hand quality checks, which means users are more likely to encounter a faulty DDR module, which can cause incompatibilities and headache for the user.
New Avexir Blitz 1.1 Original in our oppinion is the absolute best looking memory in the market today. This RAM simply looks truly amazing with a truly unique design with its white LEDs which pulsate and can really set your system apart from others making it truly unique.
Features:-
- Black PCB
- Blitz 1.1 Original High Performance Heatspreaders
- White LED Strobe lighting effect
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz
- Speed: 2400MHz
- CAS Timings: 10-12-12-31
- Voltage: 1.65v
- Dual Channel Kit: (2x4GB)
- 100% tested in Intel & AMD based motherboards (Only Intel Haswell mainboards for frequencies beyond 2400Mhz)
- Lifetime Warranty
Only £89.99 inc VAT.
ORDER NOW
Will that memory fit under a D14? Apparently the spreader comes off but is that just the top or the whole thing? Can't find this info anywhere.
From the pics it looks like there's little screws which allow you to take the lightbar off. But if you're going to be doing that anyways you might as well go for some cheaper RAM with normal heatspreaders. :p
E - Yep, looks to be removable from this review
"The top light bar seems to be held in place with four screws, and looks to be easy to remove, should you wish to do so. This is especially useful for LN2 overclockers and this is even mentioned by Avexir on the back of the box!"
Yep I presume you can put the screws back in after taking the top off to hold the sides on but I can't find any confirmation.
