**Today Only 18/04/2012** KFA2 GeForce GTX 570 & MSI GeForce GTX 580 OC Twin FrozR II
22 Aug 2010
Immense graphics deals today!
KFA2 GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card @ £191.99 inc VAT
Maximize your DirectX 11 gaming experience with the GeForce GTX 570 graphics card powered by NVIDIA Fermi architecture. The GeForce GTX 570 graphics card takes DirectX 11 gaming to a whole new level with hardware tessellation technology that enables unprecedented levels of detail and clarity for stunning in-game graphics that push the visual boundaries and rival reality. NVIDIA PhysX technology enhances the life-like visuals with realistic physics processing capabilities for virtual interaction that resembles reality for unmatched gaming immersion with the GeForce GTX 570 graphics card. NVIDIA 3D Vision readiness prepares gamers for the third dimension with unrivaled stereoscopic 3D effects when pairing with compatible 3D displays.
KFA2's innovative single flip-fan design allows you to easily clean dust from the fan and heatsink offering you maximum cooling efficiency and extended runtime.
PhysX is designed specifically for hardware acceleration by powerful processors with hundreds of cores. Combined with the tremendous parallel processing capability of the GPU, PhysX will provide an exponential increase in physics processing power and will take gaming to a new level delivering rich, immersive physical gaming environments.
NVIDIA CUDA technology is the world’s only C language environment that enables programmers and developers to write software to solve complex computational problems in a fraction of the time by tapping into the many-core parallel processing power of GPUs. With millions of CUDA-capable GPUs already deployed, thousands of software programmers are already using the free CUDA software tools to accelerate applications—from video and audio encoding to oil and gas exploration, product design, medical imaging, and scientific research.
Expand your games across three displays in full stereoscopic 3D for the ultimate “inside the game” experience with the power of NVIDIA 3D Vision and SLI technology. NVIDIA Surround also supports triple screen gaming with non-stereo displays.
NVIDIA 3D Vision brings a fully immersive stereoscopic 3D experience to the PC. A combination of high-tech wireless glasses and advanced software 3D Vision transforms hundreds of PC games into full stereoscopic 3D. Users can even watch 3D movies and 3D digital photographs in crystal-clear quality.
Delivers up to 2x the performance of a single GPU configuration for unequaled gaming experiences by allowing two cards to run in parallel. The must-have feature for performance PCI Express graphics, SLI technology dramatically scales performance on today's hottest games.
NVIDIA PureVideo HD Technology
Blu-ray and HD DVD movies are bringing a new level of movie-viewing experience; with high-definition image quality far surpassing standard-definition DVDs. NVIDIA PureVideo HD2 technology provides unsurpassed Blu-ray and HD DVD movie picture quality.
Features:-
- Core Clock: 732MHz
- Innovative cooling design with easy to clean fan for reliable and superior performance
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 2 years
Only £191.99 inc VAT.
ORDER NOW
MSI GeForce GTX 580 OC Twin FrozR II 1536MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Nickel-plated Copper Base: Large size of Copper Base can dissipate the heat of GPU faster.
Dual 8CM PWM Fans: Dual fans provide double air flow. Air flow from dual fans can cool down whole module at once.
Five heat pipes with SuperPipe Technology: Five heat pipes can provide faster heat dissipation.
Form-in-one heat sink: Form-in-one heat sink covers the memory and power module
19ºC cooler and 8.4dB quieter compared to reference design
Features:-
- Core Clock: 800MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Memory: 1536MB GDDR5
- Memory Clock: 4096MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Only £299.99 inc VAT.
ORDER NOW
