***Today Only 18/07/2012*** BenQ GW2750HM 27" Widescreen LED Pro Monitor & Samsung Green 8GB Memory
22 Mar 2011
Cheshire
BenQ GW2750HM 27" Widescreen LED Professional Monitor - Black @ £179.99 inc VAT
After launching the world's first VA LED monitor, BenQ - the world's leading LED monitor brand - is now taking the lead to introduce VA LED to our home & office offering: GW Series! Built with the dream combination of LED with VA panel, GW Series is bound to bring a whole new visual experience and enjoyment to you with truly authentic colors, deeper blacks, higher contrast and sharper details.
The GW2750HM comes with an ultra-high native contrast ratio of 5000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun! The latest HDMI high-speed multimedia interface* makes these monitors incredibly convenient to use – now you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future. Enjoy high dynamic videos without ghosting or other artifacts with 4ms GTG response time.
Experience the truest colors of the world with the BenQ Senseye® Human Vision Technology. With the help of its six proprietary calibration techniques, Senseye® 3 delivers only the best viewing quality in each of its six pre-set viewing modes –Standard, Movie, Game, Photo, sRGB, and Eco – with the Eco Mode especially designed to save power and money.
Specification:-
- Screen Size: 27"W, VA LED
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.248 mm
- Brightness: 250 cd/m2
- Contrast Ratio: 5000:1
- DCR: 20M:1
- Response Time: 4 ms GTG
- Display Area: 476.64 x 268.11 mm
- Display Color: 16.7 million
- Viewing Angle (L/R;U/D) (CR>=10): 178 / 178
- Terminals: D-sub / DVI-D / HDMI / Headphone jack / Line in
- VA LED Technology
- Senseye® Human Vision Technology (plus Senseye 3)
- Advanced Motion Accelerator (AMA)
- HDCP Support
- Speaker: 1W x2
- VESA Wall Mounting (mm): 100 x 100 mm
- Warranty: 2yr
Was £191.99 Inc. VAT
Only £179.99 Inc. VAT
ORDER NOW
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £41.99 inc VAT
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB).
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
Features:-
- Model Name: MV-3V4G3D/US
- Main Board: INTEL/AMD
- System: DESKTOP/SFF
- System Type: DDR3
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets
- CAS Latency: 11-11-11-28 1N
- Capacity: 8GB (4GBx2)
- Speed: DDR3-1600 (PC3-12800)
- Test Voltage: 1.25-1.55V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 240-pin DIMM Low Profile
- Warranty: Lifetime
Overclocking Features (Not Guaranteed)
- 1600MHz (7-8-8-24 1N) @ 1.40v
- 1866MHz (9-9-9-27 1N) @ 1.40v
- 2000MHz (9-10-10-28 1N) @ 1.45v
- 2133MHz (10-10-10-28 1N) @ 1.45v
- 2400MHz (11-11-11-28 2N) @ 1.50v
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M
Was £59.99 Inc. VAT
Only £41.99 Inc. VAT
ORDER NOW
Great! I must have been the first to buy the ram this morning.
Unfortunately I won't get to use the ram for several months before I can save and buy the rest of the components around them...
Before I order some of this memory, is there any real advantage over the 1600mhz vengeance I currently have?
