**Today Only 18/08/2011** MSI GeForce GTX 580 Lightning & Iiyama ProLite B2712HDS 27" Widescreen LC
22 Mar 2011
Cheshire
MSI GeForce GTX 580 Lightning 1536MB GDDR5 PCI-Express Graphics Card @ £389.99 inc VAT
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled N580GTX Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records!
Key Features
Industry-leading Power4 Architecture for Overclocking Reliability.
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there.
Was £449.99 Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Iiyama ProLite B2712HDS 27" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Prolite B2712HDS-1 27” LCD Display is currently the largest screen offered by Iiyama. It features a stunning 2ms Response Time and High Definition 1920x1080 Resolution. The 50000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the HDMI and DVI connections ensure compatibility across a range of devices including games consoles and workstations. The ProLite B2712HDS has a height-adjustable stand with up to 30° rotation and up to 20° tilt.
- Height Adjustment: 85mm
- Swivel Stand: 60° (30° Left & 30° Right)
- Tilt Angle: 20° Up & 3° Down
- Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 50000:1
- Brightness: 400cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 644.0mm x 422.5~507.5mm x 263.0mm
- Weight: 8.8kg
- Warranty: 3 Years On-Site
Was £279.98 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
i would go with a CU II or mars, the fan is much quiter than the lightning`s one. OC ability is the same. the extra voltage gimmicks are good for LN2 but not for aircooling.
