**Today Only 18/10/2011** Cooler Master HAF 932 & Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler
22 Mar 2011
Cheshire
Cooler Master HAF 932 Advanced Full Tower Case with USB3.0 - Black @ £89.99 inc VAT
With pure innovative strength, Cooler Master, the leader in enthusiast computer components, has unleashed yet another prevailing arsenal to compete in the full-tower chassis segment. Proud and robust in its appearance, the HAF 932 presents its sturdy sentinel housing and revolutionary High Air Flow structure to enhance and protect any hardware component that is worthy of the highest performance. This new Advanced version includes the new USB3.0 support.
- Dimensions: 243 x 560 x 546mm (W x H x D)
- Motherboard Compatibility: MicroATX / ATX / E-ATX
- Expansion Slots: 7
- 5.25" Drive Bays x 5
- 3.5" Drive Bays x 6
- 2.5"/1.8" Drive Bays x4
- Front Cooling:1 x 230mm Red LED Fan @ 700RPM, 19dBA
- Side Cooling: 1 x 230mm Fan @ 700RPM, 19dBA
- Top Cooling: 1 x 230mm Fan @ 700RPM, 19dBA
- Rear Cooling: 1 x 1400mm Fan @ 1200RPM, 17dBA
- I/O Panels: USB3.0 x 2 / USB2.0 x 4 / FireWire x 1 / eSATA x 1 / Audio x 2
Was £114.98 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) @ £15.98 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Was £19.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
