OCZ CoreXtreme 500w '80 Plus' Power Supply @ £27.98 inc VAT
The OCZ CoreXStream Series is the ideal value upgrade to satisfy essential computing needs with worry-free compatibility. The PSU is kept supremely cool with a load-controlled 120mm fan to remain quiet under load, and provides ample cable lengths for your home system application. Featuring up to 80% efficiency under typical load environments, this power supply remains rock solid and stable under pressure. Combined with a sleek look and elegant black powdercoat finish, you can be rest assured this PSU will look as good as it performs in your home office system.
- Ideal value option for home users and upgraders on a budget
- Ample cable lengths to suit various applications and system configurations
- Continuous output rated at 30¢XC ambient temperature
- 80% efficient at typical loads
- Dual +12V rails for efficient power distribution in your system.
- Compliant with ATX12V v2.2 standard for worry-free compatibility
- A temperature and load controlled 120mm fan for whisper quiet operation
- ErP compliant for low power usage in standby
- Active Power Factor Correction (PFC) to effectively regulate input voltage
- Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
- Safety Approvals: CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
- Elegant black powdercoat finish for a sleek and simple look
- 3-Year OCZ PowerSwap Warranty, no endless return-for-repair loops
- 1 x 20+4-pin ATX
- 1 x 4+4-pin ESP/12V CPU
- 1 x 6+2-pin PCI-E
- 1 x 6 pin PCI-E
- 2 x 4-pin Peripheral
- 4 x 5-pin SATA
- 1 x FDD
Was £32.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) @ £39.98 inc VAT
Combining proven components, state-of-the-art technology and industry-leading manufacturing expertise, the Seagate Barracuda 7200.12 drive - the 12th generation of this award-winning desktop hard drive family - delivers 500GB of high-performing, eco-friendly digital storage.
- Capacity: 500GB
- Cache: 16MB
- Interface: SATA 6GB/s
- Spin Speed: 7200RPM
- Seek Time: 8.5ms
- Warranty: 1 Years
Was £49.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
- 1 x 20+4-pin ATX
- 1 x 6+2-pin PCI-E
- 1 x 6 pin PCI-E
- 4 x 5-pin SATA
- 1 x FDD
Was £32.99 Inc. VAT
ORDER NOW
- Capacity: 500GB
- Cache: 16MB
- Seek Time: 8.5ms
- Warranty: 1 Years
Was £49.99 Inc. VAT
ORDER NOW
