**Today Only 19/01/2011** G.Skill RipJawX 4GB 1600MHz DDR3 & LiteOn iHBS112 12x BluRay-RW
22 Aug 2010
Today Only, we have 30 units of G.Skill RipJawX 4GB 1600MHz DDR3 Memory for only £49.98 inc. VAT. Designed specifically with the Intel’s highly anticipated Sandy Bridge platform. The G.Skill RipjawsX memory delivers more bandwidth and performance than ever.
We also have 20 units of LiteOn iHBS112 12x BluRay-RW for just £74.95 inc. VAT. Combining a fast start up and 12x recording speed. Play and enjoy full HD Blu-ray videos at 1080p.
LiteOn iHBS112 12x BluRay-RW / 16 x DVD±RW Drive - Black (OEM) @ £74.95 inc VAT
Combining fast start up, SATA interface technology, and 12x recording speed, the iHBS112 allows you to rapidly burn up to 25GB on a single layer disc, or 50 GB on a double layer disc. Reliably record 9 hours of HD video, thousands of high resolution photos, or backup vital business documents. Play and enjoy full HD Blu-ray videos at 1080p using the included Cyberlink BD Solution software suite with PowerDVD utility. Auto Balancing decreases vibrations caused by unbalanced discs, reducing operational noise, reducing read errors, and performing perfect burns on a wide range of media. Lite-On’s exclusive SMART utilities ensure that every disc is recorded at maximum speed and maximum quality. powerful SMART Burn optimizes the burn quality of each disc eliminating the burn failure of costly blank Blu-ray discs.
- SATA Interface
- Includes Cyberlink PowerDVD
Write Speeds
- BD-R SL: 12x
- BD-R DL: 8x
- BD-RE: 2x
- DVD-R: 16x
- DVD-R DL: 8x
- DVD-RW: 6x
- DVD-RAM: 12x
- DVD+R: 16x
- DVD+R DL: 8x
- DVD+RW: 8x
- CD-R: 48x
- CD-RW: 24x
Read Speeds
- BD-ROM: 8x
- BD-R: 8x
- BD-RE: 8x
- BD-RE DL: 6x
- DVD: 16x
- CD: 48x
Only £74.95 inc VAT.
ORDER NOW
G.Skill RipJawX 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (F3-12800CL7D-4GBXM) @ £49.98 inc VAT
G.Skill has announced the development of its brand new RipjawsX series memory modules, designed specifically for Intel Sandy Bridge LGA1155 processors, and H67 and P67 motherboard platforms. The new RipjawsX series consists of a complete range of memory solution, from DDR3 1,333MHz, 1,600MHz, 1,866MHz, 2,133MHz, 2,200MHz to 2,300MHz. Combined with the Intel’s highly anticipated Sandy Bridge platform, G.Skill RipjawsX series memory kits deliver more bandwidth and performance than ever.
Building on the strong success of the first generation Ripjaws brand in performance memory kits, every single RipjawsX memory kit is hand-tested on an Intel Sandy Bridge platform in accordance with G.Skill's strict internal testing procedure, to ensure the best in class performance, compatibility and reliability across a range of popular motherboards. It is the perfect memory solution for PC gamers, performance workstations, enthusiast power users and anyone who loves the cutting-edge of technology!The following list shows the detail specifications of G.Skill RipjawsX family.
Model Name: F3-12800CL7D-4GBXM
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
CAS Latency: 7-8-7-24 2N
Capacity: 4GB (2GBx2)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.5V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Only £49.98 inc VAT.
ORDER NOW
Hi guys :)
Sorry to ask again, but is this ram compatible with the original Ripjaws pc3-12800 CL7 as per my sig? Thanks :)
That RAM is sweet for OCing on Sandybridge, will go as low as 1.40 volts!
did you test this on the p8p67 pro by chance? i dont see it on the QVL.looks sweet though great price and the c6 has now gone up in price so this looks like the best ram atm.
