MSI HD 6970 OC Lightning 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £239.99 inc VAT
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records!
Key Features
Industry-leading Power4 Architecture for Overclocking Reliability
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there.
Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.
Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.
King of Extreme Overclocking
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking
Carefully Selected Materials
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
Specifications
Stream Processors - 1536 Units
Core Clock - 940 MHz
Memory Clock - 5500 MHz
Memory Size - 2048MB GDDR5
Memory Bus - 256 bits
Output - Mini DisplayPort*2 / HDMI / DVI*2
TDP - 269 W
Card Dimension - 310x127x40mm
Form Factor - ATX
DirectX 11 - Y
OpenGL 4.0 - Y
CrossFireX - Y
Eyefinity - Y
AVIVO HD - Y
PowerPlay - Y
HDCP- Y
- World’s first 18 phase PWM on HD 6970.
- Independent Memory Power support.
- Copper MOS with 2x high current capacity.
- Proadlizer*4 to optimized power supply.
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter.
- Propeller Blade technology for 20% more airflow.
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation.
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.
- Support voltage adjustment of GPU/Memory/VDDCI
- Military Class II Components for longer product lifespan.
- LPL (Lightning Power Layer) for the stable power supply.
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!
- Now with Three Year Warranty
- Supplied with FREE Deus-Ex PC Game (Subject to availability)
Was £249.95 inc. VAT
Only £239.99 inc. VAT
ORDER NOW
Sapphire HD 7970 OC 3072MB GDDR5 PCI-Express Graphics Card - AMD 3 for FREE Promotion @ £419.99 inc VAT
The SAPPHIRE HD 7970 OC Edition features SAPPHIRE’s new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load. The HD 7970 from AMD is the most powerful single chip GPU ever built - it has a new internal structure with 32 compute units and a total of 2048 Stream processors. The SAPPHIRE HD 7970 OC Edition ships with a raised core clock speed of 950MHz, and 1425MHz for the memory. Its Dual BIOS switch allows users to select the higher performance settings of 1GHz core and 1450MHz memory, making the fastest card in its class. This setting also uses a more aggressive fan profile and raises the limits for maximum overclocking.
Features:-
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1000MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5800MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 2yr Warranty
- AMD 3 for FREE Promotion including Dirt 3 Showdown, Nexuiz, Deus Ex Games (Subject to availability)
Was £429.95 inc. VAT
Only £419.99 inc. VAT
ORDER NOW
Key Features
Specifications
TDP - 269 W
Form Factor - ATX
DirectX 11 - Y
OpenGL 4.0 - Y
CrossFireX - Y
Eyefinity - Y
AVIVO HD - Y
PowerPlay - Y
HDCP- Y
ORDER NOW
Features:-
- 2yr Warranty
ORDER NOW
