Today only deals! Memory heaven, for those that need to upgrade your RAM at a great price.
TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) @ £59.99 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 9-11-11-28 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 10-10-10-27
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 19,200MB/Sec (PC3 19200)
- Heat Sink Aluminum heat-sink
- Working voltage 1.65V
- Warranty Lifetime warranty
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
Only £59.99 inc VAT.
ORDER NOW
TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38GM1600HC11DC01) @ £43.99 inc VAT
Keeping abreast with the latest trend to launch new products to replace the old, Team Group is now offering a new choice of superb value expansion with its ELITE DDR3. ELITE DDR3 features outstanding product quality that users have come to expect from Team Group and the product has also passed the strictest tests for quality assurance. Not only that, Team Group’s ELITE DDR3 is manufactured with full compliance to the specifications prescribed by JEDEC (Joint Electron Device Engineering Council) and has gone through extensive burn-in tests. ELITE DDR3 features standard 240 Pin design and operates on 1.5V of power to achieve low power consumption with a truly eco-friendly specification. In addition, TEAM ELITE also comes in a variety of selections with varying frequencies and capacities to satisfy consumers with different needs.
Features:-
- Module Type 240Pin L-DIMM 1600
- CL-tRCD-tRP-tRAS 11-11-11-28
- DRAM Density 256x8 / 512x8
- Data transfer bandwidth 12,800MB/Sec (PC3 12,800)
- Working voltage 1.5V± 0.075V
Only £43.99 inc VAT.
ORDER NOW
Features:-
ORDER NOW
Features:-
ORDER NOW
