Good Friday morning to everyone! This fine morn, we have the MSI GeForce GTX 780 - but if that doesn't wet your whistle, we've also put the Prolimatech Megahalems up too... kind of like the woman in the red dress but with less chance of being shot by Agent Smith when you stop ogling it.
Very limited quantities so GO GO GO!
MSI GeForce GTX 780 PCI-Express 3072MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
The new GeForce GTX 780 is all about hyper-realistic gaming and next generation technology. The GeForce GTX 780 features the same record-breaking GK110 GPU used in GeForce GTX TITAN. The massively powerful NVIDIA Kepler ™ based GPU contains 50% more cores than its GTX 680 predecessor AND comes with 3GB of high-speed GDDR5 and NVIDIA GPU Boost 2.0 technology. GeForce GTX 780's 384-bit memory interface provides up to 288.4GB/sec of peak memory bandwidth to the GPU. All this combines to give you over a 40% gaming performance upgrade.
Features:-
- Gigantic 3GB GDDR5 memory for the best gaming experience & the best resolution
- NVIDIA GPU Boost 2.0 Technology for intelligent monitoring of clock speed, ensuring that the GPU runs at its peak and the game is at its highest frame rate possible. It offers new levels of customization, including GPU temperature target, overclocking, and unlocked voltage
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 902 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
_
Prolimatech Red Megahalems CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011) @ £43.32 inc VAT
By popular demand, the ever popular Megahalems now comes in Red! It has stylish black grainy matte finish for the best looking performance. If looks could kill, this heatsink would reap havoc on any competitor in its path!! Housing this Intimidator is a specially designed package that has every look of a “Collector’s Edition”! Inside the package you get not only one but two sets of fan clips for setting up an awesome arsenal of duo fans. You also get support for installation on any of the Intel's and AMD's recent platforms. Those include Socket 775, 1366,1155/1156, and of course, the newest 2011, and AM2/2+/3/3+. No longer will you have to choose which backplate to use because a specially designed universal backplate has been created for better convenience and better cooling results. What Megahalems has set in performance standards, now Black Megahalems will raise the bar one level higher! Everything else aside, if looks are everything to you, this is the one heatsink to get!!
- Stylish black grainy matte finish for the best looking performance.
- Top fin made of scratch-resistant Stainless Steel to preserve shine.
- Minimal air resistance between fins allowing best balance between noise and performance in range of . - For all out performance, fan RPM at 1600 or above is recommended.
- Heatpipes are lined up in a straight line to prevent air back draft allowing air to easily pass through the heatsink body.
- Wide gaps between fins with mathematically calculated thickness to maximize best air-to-surface cooling rate.
- Easy-to-install retention mechanism for LGA 775, 1366, 1155, 1156 and 2011 and AM2/AM2+/AM3/AM3+.
- Includes easy-to-apply high grade thermal compound, a perfect sidekick to all Prolimatech heatsinks.
- New Universal Backplate to support all Intel platforms.
- Two sets of fan clips for a duo-fan installation
- Heatsink Dimensions: (L)130mm X (W)74mmX (H)158.7mm
- Heatsink Weight: 790 g
- Heatpipes: 6mm X 6pcs
- Suggested Fan: 120mm x 120mm x 25mm or 140mm x 140mm x 25mm
- Suggest Noise Level (dBA): Below 26dBA
- Air Flow: 57 CFM
- Direction of heatsink: Faces the rear exhaust system fan
- CPU Platform: Intel Socket LGA 775/1366/1156/1155/2011 , AMD Socket AM2/2+/3/3+
Only £43.32 inc VAT.
ORDER NOW
And to everyone - enjoy your weekends!
Features:-
Specification:-
- CUDA Cores: 2304
- DirectX 11.1: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
ORDER NOW
_
- Air Flow: 57 CFM
ORDER NOW
