Today Only we have two fantastic components to help you build a nice new system. Deal stock is reduced and has a limited stock so be fast!!
Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply @ £54.98 inc VAT
The Silent Pro series is a new range of single rail power supplies from Cooler Master that's addressing a growing market demand for powerful single rail 12V PSUs. With up to 50A on the 12V rail, the SilentPro series deliveries where it count and won't have any problems powering even the most demanding SLI or CrossFire system,.
The SilentPro series is also the first power supply from Cooler Master to feature flat modular cables for improved airflow and cable management. It also comes with anti-vibration silicon pads to remove possible vibrations from the PSU.
- High Quality Japanese made capacitors
- 85% efficiency
- Copper and Aluminum heat pipes for high efficiency cooling
- Silicon shock absorption rubber pads around the edges of the power supply
- Modularized flat cable design to eliminate clutter and improve airflow inside the chassis
- Two 6+2 PCI-E connectors to support various graphic card setups
Only £54.98 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939/AM2/AM3/775/1155/1156/1366) @ £15.98 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Only £15.98 inc VAT.
ORDER NOW
- 85% efficiency
ORDER NOW
- Easy installation
ORDER NOW
