**TODAY ONLY! 20/01/2014** Arctic Silver 5 Thermal Compound & Edifier S530 2.1 Speakers
OcUK Staff
4 Feb 2013
Arctic Silver 5 Thermal Compound (3.5g) @ £4.99 inc VAT
Introducing Arctic Silver 5 With its unique high-density filling of micronized silver and enhanced thermally conductive ceramic particles, Arctic Silver 5 provides a new level of performance and stability. Now available at Arctic Silver dealers worldwide, Arctic Silver 5 is definitely The New Reference. Arctic Silver 5 is optimized for use between modern high-power CPUs and high performance heatsinks or water-cooling solutions. Arctic Silver 5 uses three unique shapes and sizes of 99.9% pure silver particles to maximize particle-to-particle contact area and thermal transfer.
Only £4.99 inc VAT.
ORDER NOW
_____
Edifier S530 2.1 Speakers 145 W RMS Sound System @ £119.99 inc VAT
The S530 / S530D packs 145 watts of power within this 2.1 speaker system. Featuring a 2 inch LCD display, multi functional wired controller for ease of volume control and a wireless remote for audio playback or jumping to the next track, the S530 / S530D can be controlled with ease. Suitable for home theatre use, computer/ PC connectivity as well as perfect for gaming, the S530 / S530D will not disappoint.
S530 / S530D 2.1 multimedia speaker system
- Total power output: RMS 35W x 2 + 75W x 1
- THD + N (testing level): 10%
- Signal to noise ratio: Greater than or equal to: 85dBA
- Frequency response: Satellites: 150Hz - 20kHz | Subwoofer: 20Hz - 120Hz
- Distortion: Less than or equal to: 0.5%
- Input sensitivity: Satellites: 600mV ± 50mV (Line in), 750mV ± 50mV (AUX input) Subwoofer: 300mV ± 50mV (Line in), 750mV ± 50mV (AUX input)
- Input impedance: 10KOhm
- Audio Input Type: Stereo RCA connector, Optical Input, Coaxil Input, 3.5mm stereo line-in
- Adjustment: Power/Standby, Master volume control, Full function EQ controls, Balance controls, Input selection, Mute, LCD display, LCD dimmer, Preset EQ system reset, Digital input recognition
- Subwoofer / bass unit: 8 inch, magnetically shielded, 4Ohm
- Midrange / high unit: 3½ inch, magnetically shielded, 8Ohm
- Tweeter unit: 25mm silk domed tweeter, magnetically shielded, 6Ohm
- Remote control: Wireless: Power, mute, volume, Balance, Bass, Treble, Subwoofer adjustment, Input, LCD light control, Preset EQ system reset, Digital input recognition Wired: LCD Display, Full Function EQ adjustment knob, Standby/on, Input selection, Headphone output, Control panel
- Subwoofer: 274mm x 309mm x 468mm
- Satellites: 116mm x 203mm x 160mm (WxHxD)
Only £119.99 inc VAT.
ORDER NOW
Having an ageing Creative 550W 5.1 sound system, what would moving to a 2.1 be like? Horrible?
Depends what the speakers would be used for. Music or films etc?
I have Edifier speakers and the sound quality is incredible, just got in from work and these are sold out would have like to have a 2.1 system. I don't like how one speaker appears to be styled different though. :confused:
Defy,
The styling difference is just a cover that missing from one speaker. I did some quick research today on net, there is not many reviews but general view is S530's are pritty good. Anyhow I ordered some to replace some R1600's. Will give a quick review how these compare to R1600's but will make sure I wait 2 weeks for new speakers to settle first!
Isn't it just a cover that can be removed?
