EVGA X10 TorQ Laser Gaming Mouse - Carbon @ £59.99 inc VAT
Built with the highest quality materials, this mouse was designed from the ground up to satisfy the needs of the hard-core gamer with a high quality laser sensor that provides up to 8200 DPI, an adjustable weight system, nine programmable buttons and a unique sizing system that allows you to adjust the height of the body.
EVGA didn't stop there though. The EVGA TORQ X10 Carbon Gaming Mouse features the highest quality Omron switches with a lifespan of over 20 million clicks. We also included a full metal base that provides solid construction, the latest Avago 9800 laser sensor providing up to 8200DPI with 1000Hz polling rate, a 6FT silver coated USB cable, and much more.
- Real Carbon Fibre Surface
- On-board storage can support up to 5 separate profiles
- Ambidextrous design supports right or left handed gamers
- Adjustable height system supports all gamers
- Adjustable DPI up to 8200 DPI with On-the-Fly Sensitivity adjustment
- Adjustable weight system
- Highest quality materials including silver coated wire and Omron switches (20 million click life cycle)
- Robust software allows full control over mouse including Macro setup, profiles and OSD
- Super low friction PTFE mouse feet
Technical Details:
- Dimensions: 57.15 x 31.75 to 38.1 x 114.3 mm (W x H x D)
- Color: Black-red
- Weight: 121-134 g
- Layout: Left & right hand operation
- Sensor: Laser
- Resolution: 8,200 dpi (Avago 9800) / li>
- On-board memory: 512kB
- profiles: 5
- Programmable Buttons: 9
- LED lighting: brightness and color customizable
- LED colors: Red, Green, Blue, Yellow, Orange, Pink, Purple
- Half-life: 20 million clicks
- Connection: USB (black plated)
- USB report rate: up to 1,000 Hz
- Cable length: 1.8 m (silver-umantelt)
- Compatibility: Windows 8, 7, Vista, XP
- Features:
- Basic design of solid steel
- multicolor LED Beluchtung
- weights system
- Avage 9800 laser sensor
- surface friction of PTFE
- 9 programmable buttons
Only £59.99 inc VAT.
ORDER NOW
______________
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System - 232 Watts RMS @ £161.99 inc VAT
Since you have only one PC speaker system, you don’t want to make sacrifices. That’s why Corsair has created the SP2500.
At its heart are six Class D amplifiers driven by an ultra-efficient power supply. The 8” subwoofer driver is housed in a fourthorder bypass enclosure for clean, tight bass response that can seriously shake the room. The bi-amplified satellites use specially developed 3” drivers and custom-designed, ferrofluid-cooled 1” silk dome tweeters for detailed audio reproduction across the entire spectrum with great stereo imaging and a generous sweet spot. A programmable digital signal processor lets you craft the audio to your liking. It’s all under your command with the 1.8” (4.6cm) color display desktop controller.
- 232 Watts RMS of continuous power delivery through six Class D amplifiers
- 8” subwoofer with durable rubber surround in a fourth-order bandpass enclosure
- Bi-amplified satellites with 3” drivers and 1” ferrofluid-cooled silk dome tweeters
- Clean, high-fidelity audio reproduction with excellent stereo imaging
- Programmable digital signal processor for advanced dynamic audio processing
- Wired desktop controller with 1.8” (4.6cm) color TFT display and multi-lingual interface
Specification:
- Frequency response of 35Hz – 20kHz +- 3dB
- 232 Watts of total power (measured via FTC “RMS” method)
- Subwoofer: 18.1” x 10.2” x 11.7” (46 x 25.8 x 29.7cm) enclosure with fourth-order bandpass design for accurate bass reproduction
- Subwoofer: 8” subwoofer driver with durable rubber surround
- Subwoofer: Bridged dual 60 Watt class-D amplifiers with integrated DSP for 120W of power (measured via FTC “RMS” method)
- Subwoofer: Ultra-efficient integral power supply with 100V – 240V AC input
- Satellites: Bi-amplified, two-way design with detachable audio cables
- Satellites: 3” midrange drivers
- Satellites: 1” custom-designed, ferrofluid-cooled silk dome tweeters
- Satellites: 4.25” x 4.7” x 6.25” (10.8 x 12 x 15.9cm) enclosures with asymmetrical tweeter placement for superior stereo imaging
- I/O, Controls, and Programming: PC input on subwoofer
- I/O, Controls, and Programming: Dual 3.5mm auxiliary inputs (one on subwoofer, one on desktop controller)
- I/O, Controls, and Programming: 3.5mm headphone out with digital signal processing
- I/O, Controls, and Programming: Wired desktop controller with 1.8” (4.6cm) color display and multi-lingual interface
- I/O, Controls, and Programming: Digital signal processor with active crossover capability
- I/O, Controls, and Programming: Mod X™ theatrical audio processing for Blu-Ray and DVD audio that recreates the theatre experience
- I/O, Controls, and Programming: Dynamic DSP programs and EQ curves for late night listening, environment simulation, and optimal enjoyment of games, movies, and music
- Package Contents: x1 subwoofer, x2 satellites, x1 desktop controller with 6’ (1.8M) cable, 3.5mm to stereo RCA cable for PC input, 6’ (1.8m) satellite cables with ATX connectors, Power cable, User Guide
- Retail box dimensions: 22.75in L x 19.75in W x 15.75in H (57.8cm x 50cm x 40cm)
- Weight: 30.75 lb (13.9 kg)
Only £161.99 inc VAT.
ORDER NOW
Technical Details:
- Color: Black-red
- Weight: 121-134 g
- Sensor: Laser
- profiles: 5
- Features:
- weights system
ORDER NOW
______________
Specification:
ORDER NOW
